P1349 Oil Control Valve - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 2nd Generation (2000-2004)
2nd Generation (2000-2004) Specific discussion of the second generation Toyota Avalon
Old 10-04-2011, 09:58 AM   #1 (permalink)
View T-Gale's Photo Gallery
2nd Generation P1349 Oil Control Valve
Hello Toyota Nation family, I have a few questions. Do you need to empty/change your oil in order to change the oil control valves? And is there anything specific (like steps or procedures) that someone would need to know before changing them out? Or is it a simple loosen, pull and replace?
T-Gale is offline   Reply With Quote
Old 10-04-2011, 12:05 PM   #2 (permalink)
View bobflood's Photo Gallery
As they are fairly high up on the engine, there should be no need to drain oil first. I have never done this, but the explanations I have seen indicate that it is fairly straightforward. Do a search on this site - I'm almost positive this is where I have seen words about it.
2002 Avalon XLS; Black with grey interior; no mods; 2nd owner; 165K+ miles.
bobflood is offline   Reply With Quote
The Following User Says Thank You to bobflood For This Useful Post:
T-Gale (10-04-2011)
Old 10-10-2011, 03:59 AM   #3 (permalink)
View Mr. Glen Oaks's Photo Gallery
2nd Generation Oil Control Valves
There are a few posts on this, I just wanted to add my experience. First and foremost, Do Not Wait on this code. I did out of lack of research and paid dearly. It screws with your timing. It fouled my plugs and blew up 2 ignition coil packs!
The change out is pretty straight forward. The openings are tranny side of the engine and up top close to the head covers so you dont necessarily have to drop the oil but there is a filter for each O.C.V on each bank just below the O.C.V's behind a big bolt. At the minimum you should clean these out. They are pretty cheap so I just replaced mine since I was in there anyways. You will lose some oil out of these holes. I do an oil change any time I open up my engine just in case. You can't be too careful with these engines (Search Avalon Sludge for some horror stories)
The plastic connectors are super fragile so be careful and these engines are very touchy about non OEM so only use the real Denso / Toyota parts. I will plug my new friend:
Gary Smith
Parts Manager
Toyota of Newnan
2 Herring Road
Newnan, GA 30265
(678)854-9601
www.toyotaofnewnan.com
He has been a Great help and gives Toyota Nation members a discount! Great Customer Service and Super helpful. Got my parts quick and cheap, can't beat it.
Mr. Glen Oaks is offline   Reply With Quote
The Following User Says Thank You to Mr. Glen Oaks For This Useful Post:
T-Gale (10-10-2011)
Old 10-10-2011, 11:19 AM   #4 (permalink)
Mr Glen.. thanks a lot for the info. And i will reach to the your guy. Thanks!!
Old 10-18-2011, 11:24 AM   #5 (permalink)
leakyseals's Avatar
Gameroom cash: $167700
View leakyseals's Photo Gallery
I just resolved P1349 on a corolla with nothing more than a Mobil 1 High Mileage 5w-30 oil change. CEL went out after about 500 miles. Oil is really bad at 1500k now, lights still out. Looking in the filler, clearly the sludge and varnish are diminishing. Pretty powerful cleaners in that oil. Towards the end of 5k OCI I plan to run some kreen fo 1k as a follow up.
leakyseals is offline   Reply With Quote
