Front end squeak/chirp when I apply the brakes on a bumpy road
Why does my front end squeak/chirp when I apply the brakes on a bumpy road? I have a 2002 Toyota Avalon XLS with 187,000 miles on it, but in great shape. The squeaking/chirping noise has been going on for about 30,000 miles during which time I have replaced the struts, sway bar bushings, sway bar links, brake pads and shims, and tires. The noise doesn’t occur until I have been driving for a while (10+ miles). It doesn’t occur unless the brake is applied. The rotors seem fine – not warped but possibly close to minimum replacement thickness. I can drive over the same bump with no brake applied and the noise doesn’t occur. It seems like I have to be going at least 10 mph for it to happen. It is not the traditional brake squeal due to bad pads, shims, etc. It doesn’t seem like a bearing issue because it never happens unless the brake is applied. And it isn’t a long steady squeak (like a loose belt or rotors being scarred).
One additional problem– probably not related but I would love some advice here too – but when I replaced the struts, links and bushings the tell-tale ‘clunking’ noise came back within a day. Jacking the car up would make it disappear for a day. My mechanic suggests that the mounting plates at the top of the strut should be replaced too, but that will cost as much in labor as the original strut job! Any ideas?
