Originally Posted by moonroof
When I get a bit of time I'll try opening the door panel. It is not tough to take it apart and reassemble it, is it?
I haven't done it on the Avalon. I did remove the panels on my truck when I was putting new speakers in, and according to the Hayne's it's the same procedure.
In a nutshell, you have to remove all the screws and then pull the panel up off of the clips holding it on the door. There should be a screw under the bezel on the handle. You have to pry that up to get to it. Then disconnect all the electrical connectors before removing all the other screws.
A trim tool would be handy. In fact, step 5 says: "Remove the door trim panel retaining screws, then carefully pry the panel out until the clips disengage. Work slowly and carefully around the outer edge of the trim panel until it's free. Most of the screws on the door panel are covered by small plastic discs, which must be pried out before removing the screws."
Once it's loose, you pull up to remove. Then you unplug wiring harnesses and disconnect the door handle cable.
Guess it isn't too easy.
One last thing. Be careful of sharp metal edges if you have to dig around in the door. Gloves recommended.
