Tranny Transmission Slipping Slippage at high speeds - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 2nd Generation (2000-2004)
2nd Generation (2000-2004) Specific discussion of the second generation Toyota Avalon
Old 01-29-2012, 11:07 PM   #1 (permalink)
The Spirited Driver
View avalonshoe's Photo Gallery
I was traveling down Interstate 10 at 70mph, and needed to switch lanes because a car was on my tail. As soon as I stepped on the accelerator, the RPM spiked from 2500 to 6500rpm while the car was slowing down (from 70 to 60). (This was on an incline on a very high bridge in New Orleans
). It's very dangerous since there is no shoulder and the very steep incline claims many breakdowns almost daily. I stopped immediately right before the shoulder lane ended, cycled through all the gears, and backed my car down from the bridge to take a longer route on another bridge. I brought the car back up to 70mph on the way home and it seems fine, but I am hesitant to take it out to work tomorrow...
I checked the fluid a moment ago. The fluid is still clear red and levels are good. It's been about 60k miles since the last drain/fill. Car has about 185k miles.
Is there anything else I can do? I planned on changing the tranny fluid when Spring came around but I'm guessing the service will be done asap. I will switch to synthetic since I purchased a pro-king tranny filter kit and 12 quarts of Royal Purple Max Synthetic ATF about 2 months ago. I hoping the worse case scenario is that the torque converter would need to be change..
avalonshoe is offline   Reply With Quote
Old 01-30-2012, 08:26 PM   #2 (permalink)
Bdub215's Avatar
Gameroom cash: $317265
View Bdub215's Photo Gallery
Don't do any more drain and fills. Every time you do you take a little bit of the clutch material away. And at your mileage their wont be much left. Hate to say it but the trans is on its way out. You just need to ride it out now.
Sent from my iPhone using Autoguide
93 Lexus ES300 5spd I/E URSB
Bdub215 is online now   Reply With Quote
Old 02-01-2012, 02:05 AM   #3 (permalink)
The Spirited Driver
Wouldn't it be a good idea to drop the pan and see if the screen is filled with sludge (clutch material) or metal chips (something majorly wrong) to isolate the problem? last time, i dropped the pan, the filter was pretty clean. Debating now to buy another working tranny and learn to rebuild this one...
Old 02-02-2012, 04:51 PM   #4 (permalink)
Bdub215's Avatar
it wouldnt hurt to see. but as far as clutch material goes, its probably flushed out already. if it was metal chips i think your car wouldnt me moving at all. Rebuild kits are cheap i saw one on rock auto for 176 plus tax and shipping. its just the labor involved is a pita.
