Front tower brace/strut bar - Toyota Nation Forum : Toyota Car and Truck Forums
2nd Generation (2000-2004) Specific discussion of the second generation Toyota Avalon
post #1 of 29 Old 05-18-2012, 02:06 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Does anyone know of a tower brace/strut bar that will fit a 03 avalon? bodyroll is killing me.
thanks
Live1521 is offline
post #2 of 29 Old 05-19-2012, 03:03 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Bump, please Anyone have any insight?
Sent from my Autoguide iPhone app
Live1521 is offline
post #3 of 29 Old 05-19-2012, 04:01 PM
Home School Valedictorian
Quoted: 3 Post(s)
A strut tower brace will not do anything for body roll, they are to tie the towers together stiffing the upper mounts to prevent alignment setting changes under hard usage (notorious on unibody chassis). They will also take some of the cowl shake out when encountering rough roads, wash board, rail road crossings, etc.
If you have too much body roll it could be time for new struts, or sway bar mounts and or end links. Maybe even a larger diameter sway bar if everything else checks out and it is still rolling over too much for your liking.
9T6AvalonXLS is offline
post #4 of 29 Old 05-19-2012, 06:03 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Cool thanks for the info, but just for my knowledge are there any strut bars out there that will fit the gen 2 Avalon?
Live1521 is offline
post #5 of 29 Old 05-19-2012, 06:19 PM
Quoted: 3 Post(s)
I don't know, new to Avalons. I have seen the first gen can use a Solara strut brace, maybe that carries over to the second gen.
post #6 of 29 Old 05-19-2012, 10:15 PM
OHC
Quoted: 0 Post(s)
Your question got me curious, so I did a Google search. Found nothing listed for the Avalon. There is an Ebay seller who has a good selection for the Camry, but it's tough to tell if they're for the 4 or the V6. I'd imagine that a brace for the V6 Camry would fit the Avalon, but it's not a sure thing. The Avalon seems to have a pretty rigid body structure, and they're not popluar with tuners, so maybe that's why there seems to be so little availabilty.
OHC is offline
post #7 of 29 Old 05-21-2012, 10:13 AM
KoG506's Avatar
Quoted: 1 Post(s)
Will this help with body roll?
http://www.whiteline.com.au/product_...t_number=BTR39
My avalon has A LOT of body roll (due to worn struts) @ 140k miles right now.
Headlight Restoration DIY w/ pics
http://is.gd/EuiN88
2013 Honda Accord Coupe
KoG506 is offline
post #8 of 29 Old 05-21-2012, 06:22 PM
Quoted: 3 Post(s)
Sure, it can. If your struts are worn out it is best to replace them first, not only does it help with the quality of the ride, it is a safety issue also. If you needed to make an emergency evasive maneuver, the vehicles reaction would be more predictable and easier to control. Braking distances can increase also as struts wear out. Worn struts can also cause the springs to wear out faster and can cause premature tire wear.
post #9 of 29 Old 05-21-2012, 06:33 PM
Quoted: 3 Post(s)
I am learning the cross compatibility of the Avalons and Camry, etc. There may be a Camry model that crosses.
You are correct there isn't much interest by the tuner crowd, maybe because of the market the Avalon is targeting.
As far as my first gen Avalon concerning a rigid body structure, It could use some help. When I have the front up on jack stands (in the proper location) the doors bind when opening or closing. A strut brace wouldn't help that but it would make the front structure more rigid.
post #10 of 29 Old 05-21-2012, 07:34 PM
Quoted: 1 Post(s)
Hmmm....Toyota may have address that on the gen 2 Avalon. I've jacked up my car by each corner and I've never had a door binding issue or trunk or hood. I did on one occasion have the hood fail to pop the first time I pulled the lever, but it did so on the second pull. I think the Avalon corners pretty well with a good set of struts like KYB and a beefier sway bar and links, like I did to my car. It handled okay with just new struts and beefier sway bar links, and also new sb frame bushings. I thought about putting a strut bar on my 2000, but after researching decided that it probably wouldn't do much to help and decided not to pursue it. I had read of the intake manifold clearance issues that others had ran into trying to fit one on the gen 2...so the stb had to be bent to address clearance issues. I'd be in favor of just saving up and replacing your worn suspension. Even Sensen struts on RockAuto would be okay and probably way better than the originals on there...and they run only about 120.00 for four. Couple that with some Deeza heavy duty endlinks when you can. It won't be a porsche, but it will be like a whole another car.
Jeff
fltwd56 is offline
The Following User Says Thank You to fltwd56 For This Useful Post:
bavarianblessed (06-20-2012)
post #11 of 29 Old 05-21-2012, 07:54 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
what sway bar did u end up going with? and where did u get it?
Live1521 is offline
post #12 of 29 Old 05-22-2012, 09:04 AM
KoG506's Avatar
Quoted: 1 Post(s)
So should I replace the springs too?
http://is.gd/EuiN88
KoG506 is offline
post #13 of 29 Old 05-22-2012, 03:33 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Just in case anyone else wanted to know, the Gen 1 (99-03) Solara Suspension support brace / Strut bar does fit a Gen 2 Avalon. The part number is 53681-33010. I found one at a local junk yard for $35. It DOES NOT touch the intake manifold or anything else on the engine. It does touch the hood insulation just a little bit, but it does not bulge up the hood at all. I know that strut bars don't make much difference when compared to new struts/sway bars/end links but I can tell a difference with it on the car. The car is much more predictable and more responsive. Just my two cents
Thanks
Live1521 is offline
The Following User Says Thank You to Live1521 For This Useful Post:
CraZySteve (07-28-2012)
post #14 of 29 Old 05-24-2012, 08:35 PM
VVT-1MZ + ES5spd
Bdub215's Avatar
Quoted: 8 Post(s)
Thanks
I can attest to this. I thought these came factory on some of these Avalons?
Also For these cars if you want notably better handling The basic list is
New struts all around
Some form of lowering kit
Whiteline, TRD, Ultraracing Rear sway bar
Toyota Factory, TRD, Ultra Racing Front strut brace.
93 Lexus ES300 5spd I/E URFSB URRSB
01 Toyota Avalon TFSB, Weapon-R, Whiteline, Fogs
Bdub215 is offline
post #15 of 29 Old 05-24-2012, 08:52 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
i don't know if they came factory with it or not, i know my avalon did not have one, thanks for the list of upgrades. what about endlinks? i hear the endlinks are a weak point also, any thoughts on aftermarket endlinks?
Live1521 is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 2nd Generation (2000-2004)
User Tag List
Linear Mode Linear Mode
« Back
