Mysterious PS fluid leak! - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 2nd Generation (2000-2004)
2nd Generation (2000-2004) Specific discussion of the second generation Toyota Avalon
Old 02-03-2005, 12:23 AM   #1 (permalink)
View ruoknow's Photo Gallery
It's been several months, i need to add some PS fluid to make the PS reservior level keep constant. it's like i need to do this every other month.
But the floor where i park the car is pretty clean. I had a well known foreign car garage in the town check it, they didn't find any problem.
Any body can give out some clue?
forgot mentioning: 96 avy xls with 84000 miles on it
ruoknow is offline   Reply With Quote
Old 02-03-2005, 12:12 PM   #2 (permalink)
Gen 4 XLE v6
jhbhatia's Avatar
View jhbhatia's Photo Gallery
I'd suggest you replace the "high pressure hose" of the p/s system. Its a 34 dollar part. If your not a diy dude, most local shops should charge you at the most (high end) $100 installed w/ labor + parts.
Desi Toyota Dude Here!!!
jhbhatia is offline   Reply With Quote
Old 02-03-2005, 12:27 PM   #3 (permalink)
Originally Posted by jhbhatia
I'd suggest you replace the "high pressure hole" of the p/s system. Its a 34 dollar part. If your not a diy dude, most local shops should charge you at the most (high end) $100 installed w/ labor + parts.
Thanks Jhbhatia for your reply.
But the hoses (both high pressureare and low pressure) are very clean, and the two boots of the steering rack isn't swollen.
Old 02-03-2005, 03:19 PM   #4 (permalink)
Gen 4 XLE v6
jhbhatia's Avatar
what happens when you turn on your engine and have someone move the steering from right to left while you visualize the engine bay! if you have already take it to a shop, then i'm guessign he's already started by doing this first....
Old 02-04-2005, 10:44 AM   #5 (permalink)
View PimpinInAvalon's Photo Gallery
had the same problem. cracked rack. only leaked when vehicle was driving and making turns... thank god for warruntee cost $469 installed
Sig removed. Violation of rule #8.
No advertising.
PimpinInAvalon is offline   Reply With Quote
Old 02-04-2005, 11:25 AM   #6 (permalink)
Thanks PimpinInAvalon,
with a cracked rack, the both boots on the rack were not swollen?
as long as there is plenty of PS fluid in the reservoir, the steering still feels very smooth for me. was that the same for you at that time?
Old 02-04-2005, 02:17 PM   #7 (permalink)
the steering felt fine untill it got low..just a little moaning here and there. i dunno what it looked like, but i was told that where the fittings for the lines went into the rack, it cracked around that area
No advertising.
Old 02-04-2005, 02:44 PM   #8 (permalink)
it was all a dream
Thanked 4,294,967,295 Times in 4,294,967,294 Posts
View Ratko's Photo Gallery
I had the same problem on my 94 V6 Camry and it was the rack aswell. Found a used rack at the local scrap yard and got it installed and now its perfect.
ratko.org
Ratko is offline   Reply With Quote
Old 02-04-2005, 03:29 PM   #9 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $263242
View csaxon's Photo Gallery
The most common place for fluid loss is the rack seals, so you might want to check and see if the bellows boots on the end of the rack are full of fluid. The rack and pinion is leaking. Poke a hole in the rack boot (not the cv boot!!!) and you’ll see the fluid pour out.
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
Old 02-04-2005, 03:40 PM   #10 (permalink)
Street-Cruiser
Ostornadoe's Avatar
View Ostornadoe's Photo Gallery
My sister had that happen in her car too. Mechanic's wanted a couple hundred to fix it, so instead she just tops it off every other week.
If everything seems under control, you're just not going fast enough- Mario Andretti
Its not how fast your car goes...its how much nerve the driver has to push it that fast.
Ostornadoe is offline   Reply With Quote
Old 02-04-2005, 03:52 PM   #11 (permalink)
thanks for all of your input!
will keep on driving it until it gets worse....
Old 02-04-2005, 04:39 PM   #12 (permalink)
Try a product called Lucas PS treatment. I hear it can stop those leaks. (this from a reputable mechanic, I've never used it.) You might look up under the body of your car to see if it's streaked by the leak. The fluid accumulates and will eventually leak.
Old 10-11-2005, 04:48 PM   #13 (permalink)
I started this thread early this year.
Now new report:
The leak stopped itself when it is hot (I live in Texas), so I didn't top off the PS for almost harf a year and the PS fluid level is very stable.
There are similar posts on other forums. It seems like a well-know problem for this car: link. Now i can confirm this symptom is temperature dependent.
Now it gets colder, i notice the PS begins leaking again. Actually, the leak is developping, since I can see a puddle of PS fluid under the driver side of my car after overnight parking (the fluid level decrease at the same time).
It is about the time to replace the rack and pinion.
Any body has hands-on experience to share?
Old 10-11-2005, 05:21 PM   #14 (permalink)
Gen 4 XLE v6
jhbhatia's Avatar
^^ So you tried the stop leak p/steering fluids? (those things bought me an additional year believe it or not).
Old 10-11-2005, 08:57 PM   #15 (permalink)
No, havn't tried them yet.
If it's really hard to fix, i will give it a try.
