I need to change the ATF in my Y2K Avalon.
I don't have a clue as to how to go about doing that right, so I'm asking for help.
If it were my Ford diesel pickup, it's easy. Here are the basic procedures for getting it done on the Ford without changing the internal tranny filter:
1a) Be sure the tranny is warm and the new ATF is at least "room temp" of around 70º F.
1) Drain the tranny pan, then replace the drain plug.
2) Disconnect the tranny cooler return line at the tranny.
3) Run a few feet of clear plastic line from the disconnected cooler return line to a bucket or drain pan.
4) Pour in new Mobil 1 synthetic MERCON/DEXRON III ATF - one-third of the total capacity of the tranny - or in the case of the Avalon about 2 quarts. Use a funnel and pour it into the tranny dipstick tube.
5) Crank the engine and let it run until a big air bubble comes down the clear plastic drain line, then kill the engine. (About two quarts should have been pumped out before the big air bubble showed up).
6) Repeat steps 4 and 5. After step 6, there should now be a total of about 6 quarts of old ATF in the drain bucket.
7) Get rid of the plastic line and re-connect the cooler return line to the tranny.
8) Repeat step 4 for the third time. After step 8, you've poured in a total of about 6 quarts of new ATF. A little more than the 5-quart capacity - to be sure we got a good flush.
9) Use the tranny dipstick to help you fill the tranny to exactly full - but not overfull.
Questions:
1) Will that basic procedure work for the Avalon?
2) How do you ID the tranny cooler return line and the tranny cooler hot line?
3) On the Ford pickup, the internal tranny filter is good for over 100,000 miles, so it gets changed about every second or third ATF change. Is that a good policy for the Avalon tranny?
4) About how much ATF will drain from the pan?
Ole Man Smokey
With an ole woman's car and a beat-up ole Ford pickup.
And proud of both of them!
