Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Headgasket tips
Thread: Headgasket tips
View Single Post
Old 12-17-2006, 04:58 PM   #15 (permalink)
Hemi3TC
View Hemi3TC's Photo Gallery
Does anyone prime the oil system before starting to prevent wear on the camshafts, bearings and rings.
One tip is to put assembly lube on the camshaft and cylinder walls to help prevent dry start.
I hear alot of times when people do a valve job. The engine starts buring more oil and end up needing rings. the blame is placed on the valve job causing more vacuum or something when what may have happen is dry startup which cause the rings to wear.
h3tc
Hemi3TC is offline   Reply With Quote
