Wiring Harness help!
Hey, I got a new deck and I need help with it. I already did the speaker wires and the igntion/acc perfectly fine. However I have a few things I'm not sure about.
There are 2 yellow wires from the deck and only 1 yellow wire from the wiring harness. Do I just connect both from the deck to the 1 from the harness, like in parallel or whatever?
The black ground wire from the harness... do I connect that to just about any part of my amp? (I remember doing that with the old deck)
There are 2 orange wires from the harness (illumination and dimmer) and only 1 orange wire from the deck (illumination) do I connect these in parallel or just connect the 2 illumination wires?
Also, you see many of the wires from the deck have a different kind of connector... should I just cut those off?
1995 Silverleaf Metallic Camry LE Automatic beater
1987 Buick Grand National
