Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Wiring Harness help!
View Single Post
Old 06-13-2003, 02:45 PM   #3 (permalink)
Stealth
I get angry when Im sober
Stealth's Avatar
View Stealth's Photo Gallery
It's a Clarion deck. The ground wire from the deck has a little clamp thingie so yuo can put it under a screw to connect to the chassis... And the instructions say to do that too...
Basically my main concern is the two yellow wires from the deck. My guess is that I have to connect both the yellow wire on the harness.
The descriptions of the wires coming from the right are:
Thicker yellow wire (15A fuse): Memory back-up lead - connect directly to battery.
Thin Yellow wire (3A fuse): Bus Power Lead - connect directly to battery.
Blue/White wire: amp turn on lead (i know what to do with this)
Blue wire: auto antenna lead (um i also know what to do with this, i guess i shuold cut that weird connector off?)
Black wire (ground lead): connect to vehicle chassis ground.
And from the harness packing it says (the wires coming from the left):
Yellow: 12V Battery/Memory
Blue: Power Antenna
Blue/White: Amp turn on
Orange: illumination
orange/white: dimmer
brown: phone mute (but there is no brown wire, thats ok)
1995 Silverleaf Metallic Camry LE Automatic beater
1987 Buick Grand National
Stealth is offline   Reply With Quote
