Re: Cigarette lighter doesn't work on a '97 SR-5 4-Runner
THey might *look* good, but did you actually pull them out and test them
with a multimeter??
Seems to me that the owners manual should tell you what fuses go where and
to what accessory.
"Gordon" <gjewusa@netscape.net> wrote in message
news:h95ko2h473j7fv22e8ef69558f16taqjui@4ax.com...[color=blue]
> On Wed, 20 Dec 2006 19:47:17 -0600, "Noon-Air" <Noon-Air@comcast.net>
> wrote:
>[color=green]
>>ummm.....is there a fuse box under the hood nest to the battery box??
>>news:obpjo2162vdhulhc8o2j9dv0p5qlhd23c3@4ax.com...[color=darkred]
>>> After using a portable air pump to air up my tires the cigarette
>>> lighter doesn't work anymore. I've check the fuse box near the drivers
>>> door and all the fuses look OK. Everything else works just fine.
>>> Is there a fusible link for the cigarette lighter or another fuse box
>>> that I can check?
>>> Thanks for any help.[/color]
>>[/color]
> Yeah I looked at that one. The fuses look OK also. Those under hood
> fuses seem to be for the engine and other things.[/color]
