i think your describing the same problem my truck has. i have replaced the plugs, wires, cap, rotor, knock sensor, redid the timing, did a compression test, did a vaccume line test and the truck STILL hesitates. it feels like the engine boggs down if i floor it and then finally when it gets to about 4000 it starts to pull. truck has been to local import shop 2 times and they havent fixed it yet... i have to call on monday and ask them to get my truck in again... when/IF they finally fix it, ill post again and let you know what it turned out to be.
trent
The faster you drive through a red light, the smaller the chance you have of getting hit.
Speed limits are arbitrary figures, given only as suggestions, and are apparently not enforceable during rush hour.
