HID low beam, non HID high beam - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 3rd Generation (2005-2012)
3rd Generation (2005-2012) Specific discussion of the third generation Toyota Avalon
Old 10-30-2005, 08:46 AM   #1 (permalink)
View Phantomdaz's Photo Gallery
Hello all.
I have a 2005 Avalon Touring with HID bulbs for the low beams. The high beams are regular 9005 or 9006 ( cant remember which is the high beam bulb).
When I put the high beams on, everyghing changes from a bluish tint to mixture of blue and brown and they seem to be fighting each other rather than working together.
Can anyone recommend a bulb to put in the high beam location that would not contrast the HID lamps when I put the high beams on and at least resemble the HID low beam?
I have some bluish bulbe that were the rage about three years ago but they really do not put out much light, just a blue tint.
I need the light more than the volor but was hoping to get something that would do both
Thanks
Phantomdaz is offline   Reply With Quote
Old 10-30-2005, 09:24 AM   #2 (permalink)
TACO FTW
Location: Norton Shores, MI / Houghton, Michigan (MTU) FTMFW
View 92_Gen3_5SFE_LE's Photo Gallery
I would put some 9005 Phillips Blue Vision bulbs in.
unlike the name they are actually very white so it ill look nice
92_Gen3_5SFE_LE is offline   Reply With Quote
Old 10-30-2005, 09:34 AM   #3 (permalink)
View retired00's Photo Gallery
Phantomdaz: If you go ahead with the Phillips 9005 Blue Visions, please post your results. I have the same issue with the mixed light results. I'm not as concerned with how the car appears to others as much as creating a better field of vision.
Jim
'06 Avalon Limited
'06 Lexus RX 400h
retired00 is offline   Reply With Quote
Old 10-30-2005, 10:27 AM   #4 (permalink)
TN's ExercisePhysiologist
Bunthy's Avatar
View Bunthy's Photo Gallery
heck, toss in some 9006 HID for the high beams! then it will definitly match.
j/k
I have a 96 avalon and I have aftermarket HID in them, but you swear they came factory ( no glare or crazy cutoff, nice and clean like stock! )
For my high beam, i'm using 100w bulbs with a thick upgraded harness so I don't burn out the sotck harness. The color I get from them when using it, is nice a white~yellow. Nothing that really matches the HID but definity better than your standard 65w high beams.
These are Hella 100w bulbs. Puma performance I think carries them. And on top their like $5 a pop, so you can't go wrong. I've had these for about 2 years now, now complaint. Dang at times I even think their bright than my HIDs.
My hids are 4300K by the way not the 12000000K ricers kind.
You'll like being blown
Bunthy is offline   Reply With Quote
Old 11-03-2005, 08:16 PM   #5 (permalink)
The Biggest comment Whore
Avalonman's Avatar
View Avalonman's Photo Gallery
Are "YOU" turning the lights on? If you are, don't. The Avalon will turn them on. When the driver turns them on, the drl's seem to come on for some reason(don't ask why). so, set it to "AUTO" and she(Avalon) should fix it herself.
Avalonman is offline   Reply With Quote
Old 12-10-2005, 05:27 PM   #6 (permalink)
View osidepunker's Photo Gallery
The DRL's are the high beams . When you replace the high beam bulbs, your DRL's will look much cooler Get some PIAA's. My local shop has 4 different kinds, each about $60 a pair.
2006 Avalon Touring Edition
Two D612D4's run off a D61000.1 w/ a 1.2 farad cap, in custom fiberglass sealed enclosures.
Soon to come: Tinted windows. K&N intake kit. High-flow exhaust. And a set of 20's (maybe 18's).
http://www.cardomain.com/ride/2155533
osidepunker is offline   Reply With Quote
Old 12-17-2005, 01:46 PM   #7 (permalink)
View dtech83's Photo Gallery
Yeah. PIAA's Xtreme White Plus is probably your best bet when it comes to 9000 series bulbs that are non-HID. Catz is also good, but extremely hard to find. Don't go with unknown UK or American brands as they tend to up the wattage to blow out your wiring harness. Oh, you can also consider getting Sylvania's Silverstars. From my experience, I think they are whiter than the piaas.
dtech83 is offline   Reply With Quote
Old 12-19-2005, 08:25 AM   #8 (permalink)
Bunthy's Avatar
piaas are all show no go and freakin' $$$$!!!!
Old 12-20-2005, 03:42 PM   #9 (permalink)
What kind of bulbs do you like?
