I know that people are fitting 8.5" wide rims with 38-35mm offsets. 20x8.5 with 245/35/20 set ups are fitting with no problems and there is room to spare in the back. In fact, 255/35/20 with 38mm offset will fit as well but it will be tight because is is a slightly taller set up. 255/40/18 has a nearly identical overall circumfrence as the factroy 215/55/17 and with the correct offset will fill in those wheel wells nicely. This car is begging for a much wider set up. From the factory the wheels are tucked in too much and it looks "wimpy". Just my opinion...
