Whats the closest to HID ? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 3rd Generation (2005-2012)
3rd Generation (2005-2012) Specific discussion of the third generation Toyota Avalon
Old 07-07-2006, 03:29 PM   #1 (permalink)
2006 Avalon XL
View sunny_8's Photo Gallery
So I got a 06 XL.
Wanna get it to have the bluish headlight appreance without spending 300 for a HID conversion kit.
What are the best bulbs to get ?
I saw the following :
Sylvania Cool Blue - good life and not that much $$$ (3200K)
SilverStar - Not so good life and about $5 more than Cool Blue (3400K)
Phillips Blue Vision Only from the UK, about the same as silver star (4000K)
Anyone got any suggestions ?
I wanna keep it classy, but have a tint of blue ...
Thanks
2006 Avalon XL Blizzard
sunny_8 is offline   Reply With Quote
Old 07-07-2006, 08:34 PM   #2 (permalink)
View NYLexSC's Photo Gallery
Nokya 7000k Arctic White Halogens. This is what I use with an upgraded wiring harness. They are 100w draw, very bright and a nice bluish tint with white light tho. I will try to get some better pictures this weekend of it.
Here is a link for the bulb:
http://www.partsbynet.com/nok-7211.html
Get a KYO wiring harness upgrade so that you don't burn stock wiring.
NYLexSC is offline   Reply With Quote
Old 07-08-2006, 01:54 AM   #3 (permalink)
limited05's Avatar
View limited05's Photo Gallery
Do a search on ebay for toshiba HIR bulbs.they have to be modified a little to work but they are suppoed to be very good
limited05 is offline   Reply With Quote
Old 07-09-2006, 10:10 AM   #4 (permalink)
2006 Avalon XL
Thanks for the Info guys.....so whats the life on the bulbs ? I really dont wanna be changing them every 6 months...
Also when I upgrade the harness...what does that entail ? Do I need to cut wires etc ? or is it a clip...
I assume this voids warrenty.....do you know ?
thx
Old 07-10-2006, 06:16 AM   #5 (permalink)
View sazerac99us's Photo Gallery
I put the Toshiba HIR's in mine, low and high beam. They are amazingly bright, and don't draw any more current then a stock bulb. They do not have the bluish tint that you said you wanted, but most of those bluish bulbs of stock wattage are just trying to look like HID and actually produce less light then a stock bulb. I use Osram (NOT sylvania) Silverstars on my bike, but as they werent available for the Avalon's headlights, i went with HIRs and think they are brighter. A buddy of mine put an HID setup on his bike, said he bought it for $180 or 190, and it is BRIGHT...so you might wanna think about that also.
just my 2cents
sazerac99us is offline   Reply With Quote
Old 07-10-2006, 11:25 AM   #6 (permalink)
thx
I have had these bulbs in for 7 months now, they are still burning as bright as day 1. Upgrading the wire harness is simple, just clip on the connector end of the new harness onto the existing bulb connector thats attached to the factory wiring harness (where the bulb would normally plug) and plug the other end into the bulb! Think of it as like an extension to the current harness, except its stronger and more heat resistant!
Old 07-10-2006, 01:57 PM   #7 (permalink)
2005 Matrix XR AWD
View Whelan's Photo Gallery
Silverstars, best lighting, closest look to HID, and almost as bright as some HID systems. Great lifetime, can buy them at any auto store, no modifications needed to fit, run off your same harness, no upgrading its only 65W as opposed to 55W. And the light output is legal and looks great.
Whelan is offline   Reply With Quote
Old 07-10-2006, 06:19 PM   #8 (permalink)
2006 Avalon XL
so I found the wiring harness.......
http://www.eautoworks.com/html/ORD-1-1-1-33148.cfm or
http://www.eautoworks.com/html/ORD-1-1-1-23758.cfm for a bit less
Do I need one for the high beams too ?
And the bulbs are : http://www.eautoworks.com/html/ORD-1-1-1-2660.cfm
Still need to check about the toshiba, but dont wanna do the mod.
Still aint read good things about the silver stars.......so looks like I am going with the recommendation by NYLex_sc
Did u upgrade the high beams ? if so do you need a nother pair or wiring harnesses ?
thax to all
Old 07-10-2006, 06:21 PM   #9 (permalink)
2006 Avalon XL
forgot to ask....does your car have day time running lights.....my car does just wondering how this will affect the bulb......
thanks,
Old 07-10-2006, 06:30 PM   #10 (permalink)
2006 Avalon XL
NY....the link you sent shows the bulbs to be 4100K ...and the ones I found were 7000K....so which is the one you used, I think 7K is closer to HID ......just wanna make sure before I order all the stuff..
Old 07-10-2006, 08:51 PM   #11 (permalink)
Ahhh ha, my fault. The link I posted are the bulbs I have in my Lexus. The ones you have there from eautoworks (a good place to buy from) are the correct bulbs that I have in my avalon. The DRL bulbs are a different bulb from the low beam. I have DRL also, and they are unaffected. If you upgrade the high beams also, you shouldn't HAVE to use a wire harness unless you are gonna be running the high beams on for a lengthy time period. I did the upgrade and bulbs for my headlights and foglights, so that they all color match perfectly. I bought 2 pairs of bulbs, and 2 pairs of harnesses. The KYO harness you linked to is the same harness I have.
edit: The 7000k bulbs will be brighter and have that bluish tint you are looking for, but not be a ricey blue. The 4100k bulbs I have in my Lex shine white with more of a yellow tint like a stock halogen bulb. I'm waiting for those to blow on my Lex so I can upgrade to the Nokya 7000k. I have had the current Nokya's in my Lexus since Winter of 2004.
Old 07-10-2006, 09:04 PM   #12 (permalink)
My name is Blake
View NorCalTacoma's Photo Gallery
Luminics Pure Blue headlights.
Hands down.
NorCalTacoma is offline   Reply With Quote
Old 07-10-2006, 09:07 PM   #13 (permalink)
Toyota
View farzien's Photo Gallery
Are those plug'n play bulb's or are modifications needed?
farzien is offline   Reply With Quote
Old 07-10-2006, 10:02 PM   #14 (permalink)
My name is Blake
Plug and Play.
They run at stock wattage!
www.automotivelightingusa.com is where I got mine!
Old 07-11-2006, 12:39 AM   #15 (permalink)
View osidepunker's Photo Gallery
Originally Posted by NorCalTacoma
Plug and Play.
How long have you been running them? I just bought a set of PIAA's and they blew after 2 months. At least I got my money back
2006 Avalon Touring Edition
Two D612D4's run off a D61000.1 w/ a 1.2 farad cap, in custom fiberglass sealed enclosures.
Soon to come: Tinted windows. K&N intake kit. High-flow exhaust. And a set of 20's (maybe 18's).
http://www.cardomain.com/ride/2155533
osidepunker is offline   Reply With Quote
The #1 Techone HID Kit 6000k/8000k/10000k/12000k... $250 SHIPPED! Mod-Express Supporting Vendor Sales 53 11-27-2007 12:38 PM
Consumer Reports on HID Phi General Discussion 28 01-17-2007 08:23 PM
HID Kits Questions (56k Warning) AznVR4 Camry & Solara Lounge 29 06-29-2006 10:10 AM
