'06 Avalon TSB ST002-06 Power Steering Noise Fix - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 3rd Generation (2005-2012)
3rd Generation (2005-2012) Specific discussion of the third generation Toyota Avalon
Old 07-11-2007, 04:10 PM   #1 (permalink)
View Mike Murrell's Photo Gallery
In the shifting/acceleration TSB thread here, someone commented on the power steering fix. Below is the text version of TSB ST002-06 Title: Steering Column Noise
My wife's '06 Avalon has a problem that this might fix. If I pull into a parking lot, stop the car, go inside a store and come back, then start the car and drive off slowly, I hear a rubbing sort of noise a few secs after the car starts rolling. It last a sec. or two, then clears up.
Here's the TSB:
STEERING
Title:
Models:
Technical Service
BULLETIN
March 14, 2006
STEERING COLUMN NOISE
’05 – ’06 Avalon
ST002-06
TSB REVISION NOTICE:
December 21, 2006: The introduction and the “Model” column of the Parts
Information table have been updated.
Previous versions of this TSB should be discarded.
Introduction
Some 2005 – 2006 model year Avalon vehicle customers may complain of a ticking noise
from the steering wheel while driving slowly and turning left or right. The steering column
assembly manufacturing process has been improved.
Follow the repair procedure provided in this TSB to replace the steering column assembly
and correct the noise.
Steering Column Assembly
Applicable .
2005 – 2006 model year Avalon vehicles produced BEFORE the Production Change
Vehicles
Effective VIN shown below.
Production
Change
Information
MODEL PRODUCTION CHANGE EFFECTIVE VIN
Avalon 4T1BK36B16U099714
Warranty
Information
OP CODE DESCRIPTION TIME OFP T1 T2
442051 R & R Steering Column Assembly 1.3 45250–##### 9A 40
Applicable Warranty*:
This repair is covered under the Toyota Comprehensive Warranty. This warranty is in
effect for 36 months or 36,000 miles, whichever occurs first, from the vehicle’s
in-service date.
* Warranty application is limited to correction of a problem based upon a customer’s specific complaint.
Toyota Supports ASE Certification
Page 1 of 2
STEERING COLUMN NOISE – ST002-06 Revised
March 14, 2006
Parts
Information
MODEL PREVIOUS PART NUMBER CURRENT PART NUMBER PART NAME QTY
Avalon XL,
XLS, &
Touring
45250–AC021 Same Column Assembly,
Steering
1
Avalon
Limited
45250–AC011 Same Column Assembly,
Steering
1
Repair 1. Confirm the customer complaint by driving the vehicle slowly and turning the steering
Procedure wheel left or right.
2.
If a tick noise can be heard or felt from the steering wheel when turning left or right,
replace the steering column assembly.
3.
To replace the steering column assembly, refer to the Technical Information System
(TIS), 2005 or 2006 model year Avalon Repair Manual: Steering Column: Steering
Column Assembly.
Page 2 of 2
Mike Murrell is offline   Reply With Quote
Old 03-15-2009, 01:06 PM   #2 (permalink)
View merriam1998's Photo Gallery
Would this steering column (noise) problem lead to the loss of control of the car, beside the annoying noise? How much It could cost to have it fixed?
merriam1998 is offline   Reply With Quote
Old 06-30-2011, 11:05 AM   #3 (permalink)
Gameroom cash: $236150
View grandpapa's Photo Gallery
It took me a while to find this topic
Anyway, I don't drive the Avalon much but last week, I notice there is some weird noise coming from the steering column. It sounds like a clunk..clunk? or maybe pop...pop while turning the steering wheel. More noticable when car is not moving or low speed.
the 1st post of this is coming from this forum
http://www.tundrasolutions.com/forum...t002-06-power/
but not much info on DIY
Our is 05 and don't want to spend too much. Any idea? or anyone has the same problem?
grandpapa is offline   Reply With Quote
Old 06-30-2011, 07:29 PM   #4 (permalink)
The problem in the TSB I posted above back in 2007 had nothing to do with my situation.
I personally drive fairly simple vehicles.
The '06 Avalon(my wifes car) was a BIG step up for me. Too many whistles and bells for my taste.
Turns out I was hearing the ABS going thru a self-test on take-off. By design - this will happen everytime you cycle the engine and then startup again and drive off. Occurs for just a sec. or so.
Needless to say the TSB is valid in other situations.
Old 07-01-2011, 10:03 AM   #5 (permalink)
I have read some people on Sienna forum do a DIY by adding lub around the steering column shaft booster, i will need to look deeper to see how it turns out
GEN II V6...power steering pressure hoses...easy fix? ArmyofOne Camry & Solara Lounge 4 02-07-2005 11:05 AM
Power steering noise hdsalinas Archived Corolla threads 2 08-22-2004 10:25 PM
Making some cool power (caution! For reference use only ) AngryAE101 Archived Corolla threads 5 11-03-2003 10:03 PM
Power steering replacement. 1987camry Camry & Solara Lounge 0 08-10-2002 04:08 PM
Power Steering 86CRESSIDA86 General Discussion 8 01-31-2002 04:25 AM
