05 Limited Engine Noise - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 3rd Generation (2005-2012)
3rd Generation (2005-2012) Specific discussion of the third generation Toyota Avalon
Old 03-14-2008, 05:51 PM   #1 (permalink)
View mbrem's Photo Gallery
Have noticed engine hissing noise louder then usual coming from front of engine near water pump pulley area. Sounds like a hissing noise and varies with rpm's. Have an 08 Highlander with same engine and its quiet. Have 33K miles on Limited and want to know if anyone has experienced same and what was found to be cause. Warranty running out soon and don't want to get stuck later. Any ideas would be appreciated before I take it to dealer for his song and dance.
Thanks
mbrem is offline   Reply With Quote
Old 03-17-2008, 10:08 AM   #2 (permalink)
Engine Noise Solved
The whine in the front of engine near water pump was determined by dealer to be the idler pulley and tension pulley. They have been ordered for replacement under warranty. 33K miles.
Old 05-03-2008, 08:23 PM   #3 (permalink)
James
View jamesoy's Photo Gallery
have you change your Air Filter?
jamesoy is offline   Reply With Quote
Old 05-04-2008, 07:17 PM   #4 (permalink)
Noisy Pulleys
Air filter changed to K&N. As stated previously, dealer found problem to be a noisy idler and tension pulleys. Replaced under warranty. Problem solved.
Thanks
