tire sensor lite up on dash board - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 3rd Generation (2005-2012)
3rd Generation (2005-2012) Specific discussion of the third generation Toyota Avalon
Old 04-14-2008, 07:46 PM   #1 (permalink)
View blacktoy07's Photo Gallery
i have checked all tires and spare , but sensor lights still on.
How do i reset it?
if i have a bad sensor how much would it cause, and to get installled?
can i get an after market?
Black Avalon 2007 Limited Edition - Front and Rear Splash Guard - Sunroof Air Deflector - 20% tint all around - and -
18's black on black
blacktoy07 is offline   Reply With Quote
Old 04-14-2008, 07:48 PM   #2 (permalink)
View Mike Murrell's Photo Gallery
If your car is an '07, it may still carry warranty on the failing part, if that is the reason for your problem.
Go thru your owners manual before taking the car in.
Mike Murrell is offline   Reply With Quote
Old 04-15-2008, 11:57 AM   #3 (permalink)
View Amaury's Photo Gallery
How do i reset it?
The sensor itself is all solid-state technology; hardly fail. The other side of the spectrum could be the ECU's on the car. However, yours is too new for these parts to fail as well.
What's left? Are you sure you have not deviate too much from the psi range on all tires including spare? Another remote possibility is that one or more Lithium batteries on the sensors (tire side) is/are dead.
Also, has anyone other than yourself worked on your wheel/tires just before this thing happened? Swapping/removing these devices (sensors on tires) is very easy
Amaury
'08 Limited
Amaury is offline   Reply With Quote
Old 04-15-2008, 10:17 PM   #4 (permalink)
there are batteries on them?
i switch my tires from stock to 18's.
could those be sensor break when they switch from stock to new rims?
should i ask shop to pay for replacement.
Amaury
'08 Limited
18's black on black
Old 04-16-2008, 10:21 AM   #5 (permalink)
The tire ECU on the vehicle is constantly monitoring/receiving signals from the 5 sensors, which are also transmitters. This is how the tire pressure system in your vehicle knows if your tire pressure is within specs because the sensors are constantly sending this information (pressure values) to the ECU, which compares it with the stored values in the ECU. If any one of those sensors stop sending its signal for whatever reason, your dashboard is gonna light up even if the remaining 4 are O.K.
If you changed your OEM rims, I hope you kept the original tire valve stems because this is where the sensors are. And if you did keep them there is a chance that if the valve stems were overlooked when handling the tires, at least one may have sustained damage. Since no electric power goes from the vehicle to the tires, the sensors need their own power supply in the form of disposable batteries in order to transmit their signals to the ECU. But the batteries themselves are supposed to last many years, about 10. But then again, one or some of them could fail prematurely.
Amaury
'08 Limited
Old 11-23-2008, 12:08 AM   #6 (permalink)
View lbroer's Photo Gallery
Did not think to check the spare. Thanks.
lbroer is offline   Reply With Quote
Old 11-23-2008, 12:27 PM   #7 (permalink)
View jimhuey's Photo Gallery
I had aftermarket wheels installed on my '08 Avalon. The place where I have always pruchased tires for all my vehicles changed the spare and broke the sensor. When I picked up the car, the lamp was on. I then found out that they broke the sensor and did not tell me because they "didn't know the spare was monitored". Needless to say, I now purchase tires from a different source. So much for Gateway tires.
jimhuey is offline   Reply With Quote
