The ’08 manual states that Toyota does not recommend blended gasoline, but then just right below this statement, it says that Toyota allows 10% ethanol to be used in the engine.
If you can avoid the ethanol, do it. Simply stated, the engine will consume more gas for the same mileage because ethanol contains additional oxygen. The engine’s oxygen sensors will detect the surplus, and believing that the mixture is lean will keep the fuel injector open for a little longer to get the proper air/fuel ratio for the combustion.
Hence the engine will consume more gas although you may experience a bit more of boost.
Amaury
'08 Limited
