Rolling noise - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 3rd Generation (2005-2012)
3rd Generation (2005-2012) Specific discussion of the third generation Toyota Avalon
Old 05-06-2008, 03:11 PM   #1 (permalink)
View dragonlord's Photo Gallery
Rolling noise
Hello,
I recently purchased a pre-certified TOYOTA AVALON '07 XLS with 28000 miles on it and I put about 1000 miles more on it and now I have started hearing intermittently a sort of marble rolling sound from the left back passenger under door to the middle of the drivers side.....any ideas?
dragonlord is offline   Reply With Quote
Old 05-06-2008, 09:41 PM   #2 (permalink)
fake_usa's Avatar
View fake_usa's Photo Gallery
wheel bearing??? You're still covered under factory warranty bring it to the dealer.
2005 Avalon XLS
http://www.cardomain.com/ride/3004388
fake_usa is offline   Reply With Quote
Old 05-06-2008, 09:58 PM   #3 (permalink)
it does not seem to be the wheel bearing because the rolling travels.......
Old 05-07-2008, 07:50 AM   #4 (permalink)
Avalon Enthusiast
Gameroom cash: $102015
View inov8's Photo Gallery
This symptom sounds similar to what several '05 and '06 owners reported on the Edmunds forum. It turned out to me some metallic object trapped within the tubular seat support structure. The solution was to unbolt the seat to gain access to the bottom, and than inject expanding foam into the tubular supports to effectively encapsulate the rolling object (there is no easy way to remove it). You might try a search of that site to find the detailed instructions posted by an owner (in 2005, as I recall).
You can test if this is your cause by temporarily removing the 4 bolts that retain the passenger seat to the floor, and then tilting the seat from side-to-side while listening for the offending sound. Adjjust the seat to the most forward position to access the rear bolts, and to the most rearward position to access the front bolts.
inov8 is offline   Reply With Quote
Old 05-07-2008, 09:05 AM   #5 (permalink)
Thanks...this seems more like what I hear....I will take the vehicle to TOYOTA and see what happens.....
