bypassing traction control - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 3rd Generation (2005-2012)
3rd Generation (2005-2012) Specific discussion of the third generation Toyota Avalon
Old 06-25-2008, 12:30 AM   #1 (permalink)
View jessz71's Photo Gallery
I have an 07 avalon and I was wondering if there was anyway of bypassing the traction control because I have been stuck in the snow so many times because I can't spin the tires to get out. Thanks.
jessz71 is offline   Reply With Quote
Old 06-25-2008, 07:42 AM   #2 (permalink)
Avalon Enthusiast
Gameroom cash: $102015
View inov8's Photo Gallery
The following was copied from the 2005 Avalon Features Manual, page CH-55. I have tried it in snow and it does work. Practice in advance hepls a lot. I print these instructions on a laminated card and keep it in the glove box.
Transition to the service mode (TRAC and VSC OFF mode).
The TRAC and VSC systems can be turned off by following the procedures below:
Using the parking brake and brake pedal:
1) Check that the IGN is off and the shift lever position is at P.
2) Start the engine after turning the IGN to the ON position.
3) Perform the following steps 4 to 8 within 30 seconds after engine start.
4) Turn the parking brake switch on (engage parking brake).
5) Depress and release the brake pedal twice.
6) Turn the parking brake switch on and off (engage and release) twice while depressing the brake pedal.
7) Depress and release the brake pedal twice while the parking brake switch is on.
Notice: Steps 6 and 7 should be performed within 15 seconds each.
8) Check that the VSC warning light and slip indicator are turned on. If they are not turned on, start over
from step 1.
9) The brake control system will return to the normal mode by turning the IGN to the ON position from off.
For additional details regarding transition to the service mode, see the 2005 Avalon Repair Manual (Pub. No. RM1169U).
inov8 is offline   Reply With Quote
Old 06-28-2008, 12:01 AM   #3 (permalink)
James
View jamesoy's Photo Gallery
http://www.youtube.com/watch?v=XMN-WEWM5IE
check this out, it will give u wut u want,
jamesoy is offline   Reply With Quote
Old 12-08-2008, 10:25 PM   #4 (permalink)
View Recoiler's Photo Gallery
wow) that is exactly what i'm dealing with right now) does it really works? and you can enable the sysytem back???
Recoiler is offline   Reply With Quote
Old 12-15-2008, 01:36 PM   #5 (permalink)
limited05's Avatar
View limited05's Photo Gallery
Originally Posted by Recoiler View Post
wow) that is exactly what i'm dealing with right now) does it really works? and you can enable the system back???
Yes everytime you start your car you have to do this.
limited05 is offline   Reply With Quote
Old 12-16-2008, 02:01 AM   #6 (permalink)
klex's Avatar
View klex's Photo Gallery
That seems like a headache to do all that. I took my friend's aunt's 05 avalon touring on a joyride. It had no tcs on/off switch and I wanted to smoke the front tires. In D it wouldn't so I put the lever is S mode and smoked 'em all night. And also when I floor it from a dead stop it chirps all of first and bangs off the rev limiter. This was about a year ago I may be wrong about the rev limiter part but the tires definitely smoked in S mode.
klex is offline   Reply With Quote
