They didn't make it easy.
1. DISCONNECT CABLE FROM NEGATIVE BATTERY TERMINAL(SEE PAGE 60-1 )
2. REMOVE REAR SEAT CUSHION ASSY (SEE PAGE 72-51 )
3. REMOVE REAR SEAT HEADREST ASSY (SEE PAGE 72-51 )
4. REMOVE RR SHELF COVER CAP (SEE PAGE 72-51 )
5. REMOVE REAR SEATBACK ASSY LH (SEE PAGE 72-51 )
6. REMOVE REAR SEATBACK ASSY RH (SEE PAGE 72-51 )
7. REMOVE REAR DOOR SCUFF PLATE LH (SEE PAGE 76-29 )
8. REMOVE REAR DOOR SCUFF PLATE RH (SEE PAGE 76-29 )
9. REMOVE REAR DOOR OPENING TRIM WEATHERSTRIP LH (SEE PAGE 76-29 )
10. REMOVE REAR DOOR OPENING TRIM WEATHERSTRIP RH (SEE PAGE 76-29 )
11. REMOVE REAR SEAT SIDE GARNISH LH (SEE PAGE 76-29 )
12. REMOVE REAR SEAT SIDE GARNISH RH (SEE PAGE 76-29 )
13. REMOVE ROOF SIDE GARNISH ASSY INNER LH (SEE PAGE 76-29 )
14. REMOVE ROOF SIDE GARNISH ASSY INNER RH (SEE PAGE 76-29 )
15. REMOVE PACKAGE TRAY TRIM PANEL ASSY (SEE PAGE 61-26 )
16. REMOVE CENTER STOP LIGHT ASSY
(a) Disconnect the connector.
(b) Disengage the claw and remove the center stop light assy.
Source: 2005 Avalon Shop Manual, Pg 65-30
