Based on your experience, it would be better to take the car to a good mechanic, or to the dealer if that makes you feel more comfortable. Either one of these guys will need to access the A/C evaporator core (and also the heater core, which seats just in front of the evaporator) and spray both of these units with a disinfectant to kill the mold and mildew, which right now are happily living in your evap and heater cores. They may run the fan so that some of the disinfectant spread through the ductwork, which may also be infected with these little creatures.
When you use your A/C, water droplets form in the evaporator. The heater core could pick some of this humidity because of its close proximity to the evap. This humidity (both in the evap and heater core) combined with the warm temperature and stagnant air your vehicle provide when you leave it overnight is all mold and mildew need to exist. The problem is more pronounced in humid climate and during the summer. No much of an issue during winter, since the air is far less humid and the temperature is way too cold for the tiny creatures to survive.
This is the most efficient way to eliminate your problem. The condition is preventable however.
Amaury’08 Limited
