How To Access 12v Plug - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 3rd Generation (2005-2012)
3rd Generation (2005-2012) Specific discussion of the third generation Toyota Avalon
Old 11-10-2008, 02:48 PM   #1 (permalink)
View enjun's Photo Gallery
How do you get to the power plug (backside) for the one located in the lower console mounted staight down. What to make it hot all the time not switched.
enjun is offline   Reply With Quote
Old 11-11-2008, 12:16 PM   #2 (permalink)
Avalon Enthusiast
Gameroom cash: $102015
View inov8's Photo Gallery
At a minimum, you will have to remove the upper part of the center console. For hints, see: http://members.cox.net/n0v8or/console_removal.pdf
Once removed, you may be able to access the connectors for the power outlets. Green wire is + (accessory) and black/white wire is - (ground). If the connector(s) are still not accessible, the console box (with the rear heat/AC registers) and lower part of the center console may require removal. There are two retaining screws under the carpet in the console box, and 2 that were hidden by the upper console.
To remove the lower part of the console, there are 2 nuts at the rear, and a screw toward the front.
inov8 is offline   Reply With Quote
Old 11-13-2008, 07:41 PM   #3 (permalink)
Just Another Toyota Owner
cdnacadian's Avatar
Gameroom cash: $240852
View cdnacadian's Photo Gallery
Thanks for the GREAT "How To". Great format, are there any more handy hints like that?
Keep up the good work!!
06 Avalon Limited, 01 Echo
cdnacadian is offline   Reply With Quote
