2008 avalon tps - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 3rd Generation (2005-2012)
3rd Generation (2005-2012) Specific discussion of the third generation Toyota Avalon
Old 12-05-2008, 10:18 AM   #1 (permalink)
View nav-air's Photo Gallery
Gen5 2008 avalon tps
I have a 2008 Avalon xls and as shown many times in this forum, there are many questions concerning the tire pressure warning system.my question is: is there a pressure tolerance ( plus/minus) from a 32 psi set point to be reached before the TPS light illuminates
Thanks
nav-air is offline   Reply With Quote
Old 12-05-2008, 12:14 PM   #2 (permalink)
just a nobody
The threshold where it would trigger the light is about 6 psi from where when the system is initialized: at 32 psi, it will turn on the light when it drops to 26 psi. Or at 30 psi, light on at 24 psi.
With the colder weather, you may have to add a couple of psi to compensate for the temperature drop after you have set the pressure and re-initialized the system.
N.E.O.
Old 12-08-2008, 02:46 PM   #3 (permalink)
View Amaury's Photo Gallery
You can set your own threshold value. That’s the only reason the reset switch exists.
Factory value, like NEO stated, is way too low: who needs a MIL to realize your tires needs air at, say, 26 psi UNLESS you are a very special kind of person who can’t tell your tires are under inflated at 26 psi, so I set my own reference point to a value that makes more sense to me.
Amaury
’08 Limited
Amaury is offline   Reply With Quote
