starting problem - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 3rd Generation (2005-2012)
3rd Generation (2005-2012) Specific discussion of the third generation Toyota Avalon
Old 12-23-2008, 06:51 AM   #1 (permalink)
View mintx3's Photo Gallery
starting problem
my 05 corolla xrs will not start! It's below 0 and has been for two days,the car sat for three hrs. and would'nt start.I had this prob. last winter, and i put a heat lamp on the motor all day and used a torch to heat up the inside of the air box & it started right up 6 times or so. Now I tried the same thing this year and the only thing that fired was the inside of my air box catching on fire!It's got a good batt.,spark,fuel pres.,and no check engine light. If it was the maf/air temp. it would have shown a code right? It showed a couple rich cyl. last winter after I got it started,but nothing else. It starts just fine when its a little warmer out
mintx3 is offline   Reply With Quote
Old 12-23-2008, 11:07 AM   #2 (permalink)
View toyomoho's Photo Gallery
Just guessing might be a frozen Idle Air Control (IAC) valve. This part usually bolts to the throttle body. Should have a couple of hoses running to it. A problem with this part can cause hard starting even in mild temps.
Use a hair dryer to heat the area.
Also try using some gas pedal when starting the car.
One other problem could be the cold start circuit. Typically there is a temp sensor in the coolant system that signals the computer to add more fuel when the coolant is below a certain temp. This is part of the cold start system. The sensor could be bad.
If you can pull a plug and check for gasoline. During cold start more fuel is injected. If fuel on the plugs you should be getting gas.
And check for a weak ign spark.
