window wont work after disconnecting battery - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 3rd Generation (2005-2012)
3rd Generation (2005-2012) Specific discussion of the third generation Toyota Avalon
Old 03-18-2009, 04:44 PM   #1 (permalink)
View satrrt's Photo Gallery
I disconnected my negative terminal on my 2007 Avalon to remove the radio. I eneded up having an incorrect connector for what I was doing so I reinstalled the factory radio back into the car after having it out all of about 20 minutes. The only connectors I touched were the two attached to the vent casing around the radio and the ones plugged into the radio. After reconnecting the negative cable, I see that my driver window no longer goes down automatically with the long push of the button. My front passenger window will also not go down with the driver side controls. (it will with the control on its own door). The rear windows work fine with the driver side controls. Also, my sunroof will not auto open or auto close with the long push. It will open, but I have to keep it pushed down until it is done. Is there something I just need to reset since I unhooked the battery? I remember something like this happening in my 4runner in the past. I am hoping it is something simple. Thanks.
satrrt is offline   Reply With Quote
Old 03-18-2009, 07:04 PM   #2 (permalink)
Avalon Enthusiast
Gameroom cash: $102015
View inov8's Photo Gallery
Copied from TSB PD002-05
NOTE:
Anytime the battery terminal has been disconnected, please initialize the driver’s door
power window and front passenger’s door power window after reconnecting the
battery terminal.
With ignition switch in the “ON” position, do the following:
1. Push down and hold the driver’s door power window switch to completely open
the window.
2. Pull and hold up the driver’s door power window switch until the window closes.
Continue holding the switch for approximately one second until the switch changes
from blinking to a constant illumination.
3. Check for proper operation of the “one–touch open and close” function by fully
pushing the switch briefly to the “DOWN” and “UP” positions.
At this time the power window switch for the passenger’s door window should
be blinking.
4. Push down and hold the passenger’s door power window switch to completely open
the window.
5. Pull and hold up the passenger’s door power window switch until the window closes.
6. Check for proper operation of the “one–touch open and close” function by fully
Sunroof initialization is similar.
inov8 is offline   Reply With Quote
Old 03-18-2009, 07:10 PM   #3 (permalink)
Thanks for the info. I didn't have my owners manual with me and I am sure it was in there. Everything is working great now. Thanks again.
Old 04-10-2009, 08:12 AM   #4 (permalink)
'06 Touring
View BigBoi's Photo Gallery
I knew you guys would have the answers, thx!
BigBoi is offline   Reply With Quote
Old 08-24-2010, 07:24 PM   #5 (permalink)
View sclabrl's Photo Gallery
Thanks!
Thanks INOV8! Had same problem after pulling battery-sunroof works perfect again
sclabrl is offline   Reply With Quote
