06 Limited Oil Change - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 3rd Generation (2005-2012)
3rd Generation (2005-2012) Specific discussion of the third generation Toyota Avalon
Old 04-15-2009, 07:48 AM   #1 (permalink)
turbowanabe's Avatar
View turbowanabe's Photo Gallery
Hi All!
Doing my first oil change since I bought it and have a few questions.
What's the deal with the oil filter setup? Does the 3.5 take a regular canister filter, or a paper cartridge? Is the filter hard to get at?
How much oil does this motor actually hold? Owner's manual says 6.4 quarts???
Thanks in advance!
Joe
06 Avalon Limited, Phantom Gray Pearl
03 Pontiac Vibe
1987 Buick Grand National
turbowanabe is offline   Reply With Quote
Old 04-15-2009, 08:55 AM   #2 (permalink)
tonystewart's Avatar
View tonystewart's Photo Gallery
Paper cartridge
No
6 1/2 quarts
tonystewart is offline   Reply With Quote
Old 04-15-2009, 01:05 PM   #3 (permalink)
Avalon Enthusiast
Gameroom cash: $102015
View inov8's Photo Gallery
This pdf file will give you some tips:
members.cox.net/n0v8or/avalon_oil_change.pdf
It's OK to skip the steps that involve first draining the oil out of the canister, and proceed directly to remove the entire housing. Just be prepared for more oil spillage. I've done it both ways. If you opt not to pre-drain the canister housing, there is no need to remove/replace the smaller O-ring.
inov8 is offline   Reply With Quote
Old 04-15-2009, 01:20 PM   #4 (permalink)
Thanks!
03 Pontiac Vibe
Old 11-27-2011, 07:24 PM   #5 (permalink)
View dwegelin's Photo Gallery
Nice tutorial inov8.
I'd like to throw in a couple of comments to it. The filter housing should only be torqued to 25 N-m or 18 ft-lbf. And the cap on the housing should only be torqued to 13 N-m or 10 ft-lbf.
One thing I always do is pre-load the filter with some clean oil, just put enough in so it won't spill out the housing while your screwing it back on. That will pre-lube your filter.
dwegelin is offline   Reply With Quote
