Avic F-90BT Upgrade Problem
Hi Everyone,
Well I took the plunge and had the new Pioneer installed in my 06 Avalon. He did a great job and it looks and sounds great. We do have one problem.
Right after the initial install, while I was driving home I noticed that I had very little AM reception. The FM side was full of static, but better. I returned to the installer yesterday and he tried another antenna which was great when positioned on the outside of the car but only a little better when placed on the inside of the rear window.
I have done some research and found out that the original antenna is powered. I am not sure if he was aware of this or not, but I would like to find out where the connections are to power the antenna. He ran a harness to the trunk where the old radio is mounted to maintain the AC controls. Is there a pin on the original radio which supplies power to the Antenna? If so which one would it be? If that were the case then we could run a wire to it and hopefully solve the problem. Would love to post pics, but I am not allowed at this point.
Thanks in advance for any help that you all can provide.
M
