after owning an 97, a 2000 and an 06.....I'd suggest the issu regading load limit is suspension.... not horse power. my 2000 could easily haul my enclosed trailer. The load limit, if I remember correctly, was 2000lbs. it's certainly not about power or whether or not you have the oil cooler although I'd recomend one. In fact when I investigated the need for an oil cooler for the 2000, I was specifically told it was unecessary because the radiator was so large and efficient, the fans rarely i ever routinely engaged/turned on.
I was considering improving the load capacity of my 06 by adding frame bump-stops to limit frame travel but couldn't find any that seemed to fit properly - I opted to trade the 06 for the new Venza with tow prep and have the 2500lb capacit I wanted..... difference in ride but notat all sorry.....
