Can Anyone Help!!!!! - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 3rd Generation (2005-2012)
3rd Generation (2005-2012) Specific discussion of the third generation Toyota Avalon
Old 06-28-2009, 05:30 PM   #1 (permalink)
View kevmn77's Photo Gallery
I have a 2006 toyota avalon, The problem is my passenger window switch on the drivers side door will not work, but the switch on the passenger side door will work for the passenger window. There are led lights on the switches on the drivers door. the led light on the switch for the passenger side window stays lit all the time. Does anyone have a suggestion. Thank you
kevmn77 is offline   Reply With Quote
Old 06-28-2009, 05:47 PM   #2 (permalink)
Moderator
nhcycle's Avatar
Gameroom cash: $450372
View nhcycle's Photo Gallery
Which model do you have? XL, XLS, Touring, or Limited? Bought new or used?
nhcycle is offline   Reply With Quote
Old 06-28-2009, 09:21 PM   #3 (permalink)
View Recoiler's Photo Gallery
I'd better take it to dealler. 06 should be still on warranty.
Recoiler is offline   Reply With Quote
Old 07-29-2009, 10:07 PM   #4 (permalink)
View yotatech603's Photo Gallery
Have you had the battery disconnected recently? Initialize the pass. window from the pass. switch on that door and all should be good
yotatech603 is offline   Reply With Quote
Old 08-04-2009, 11:47 AM   #5 (permalink)
Magnetic Sleeper
87XJRob's Avatar
View 87XJRob's Photo Gallery
Talking I would try recalibrating the window like you have to
when you disconnect your battery. The manual should tell you the specifics, but I believe(off the top of the head) you lower it down to about half way and then raise it and hold the button for like 5 seconds once it is closed and it is recalibrated. The auto up/down should work at this point. You will probably have to do this from the passenger side switch, though and when done right it should be lit up green again.
I would give this a try and RTFM before I took it to the dealer.
87XJRob is offline   Reply With Quote
Old 08-04-2009, 09:10 PM   #6 (permalink)
View geraldmac2's Photo Gallery
I just had this problem about an hour ago. I unhooked the battery to wire in some trailer lights. when i got done the passenger window would not work from the driver side and the autos did`nt work. The manual said to lower driver window half way then raise it all the way and hold up on the swith 5 seconds, This worked for me maybe it will work for you.
geraldmac2 is offline   Reply With Quote
