maintenance code - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 3rd Generation (2005-2012)
3rd Generation (2005-2012) Specific discussion of the third generation Toyota Avalon
Old 06-30-2009, 05:18 PM   #1 (permalink)
View Bob Coates's Photo Gallery
maintenance code
I noticed a "maintenance required" light on the dash. I called the dealer and he stated that I required an oil change. I had changed the oil myself but did not reset the mileage code. I would like to know how to reset the "maintenance required" code to eliminate it. Thanks to all.
Bob Coates is offline   Reply With Quote
Old 06-30-2009, 08:02 PM   #2 (permalink)
Dave's
Gameroom cash: $123350
View Dave's's Photo Gallery
Should be in your owner's manual or you could do a search... I'm just letting you know because believe me you'll be hearing it from others if I don't. (and maybe even if I do). Anyway, I think you set the odometer to trip A but if not it's to odometer. Turn key off. Hold trip button in and turn key to 'on' (not start). I believe 5 dashes appear and then go out one by one. Once it's complete you can release the button and turn the key off. Light should be reset until 4.5K miles when it will blink for the next 500 miles and then go solid. Anyway that's how it works on my Camry.
Dave's is offline   Reply With Quote
Old 07-03-2009, 09:44 PM   #3 (permalink)
View doc4point's Photo Gallery
Dave's is correct. And the odometer needs to be set on the odometer mileage, not trip. It is in your user's manual. It may take a while to find because the index is pretty crappy.
doc4point is offline   Reply With Quote
