Struts replacement - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 3rd Generation (2005-2012)
3rd Generation (2005-2012) Specific discussion of the third generation Toyota Avalon
Old 07-05-2009, 11:32 PM   #1 (permalink)
View mnguyen110's Photo Gallery
Struts replacement
Hi all,
I took my car to an auto shop to get me brakes pads install. When they lefted the car the noticed two things: 1) one of my front struts is leaking and then the rears was checked out and also needs replacing. 2) The studs and wheel lug are rusted/corroded.
1) How long do struts last under normal driving?
2) How to the studs and wheel lug get rusted/corroded in California?
My avy is an 05 and at 55K miles. The auto shop said that it would cost $500 installed for 4 KYB "life time warrenty" struts.
Thanks in advance.
mnguyen110 is offline   Reply With Quote
Old 07-06-2009, 10:10 AM   #2 (permalink)
View avy327's Photo Gallery
wha model avalon do u have ? kyb struts are stiffer than touring so if u have a limited it will be a big differnce
avy327 is offline   Reply With Quote
Old 07-06-2009, 02:47 PM   #3 (permalink)
'07 Avalon Limited
Tom in Tacoma's Avatar
Gameroom cash: $354645
View Tom in Tacoma's Photo Gallery
It's hard to say how long struts will last. Much of it depends on how and where the car was driven, or if there was a defect in a strut to begin with. 55k seems a bit low for a strut to fail.
Studs and wheel lugs can rust in CA the same way they do elsewhere. I'm pretty sure you wash your car - your brake rotors will get a coat of rust on them from sitting overnight just from washing the car. Unless the rust is more than surface rust (I'm talking pitting and flaking) I wouldn't worry about it.
Go get a second opinion on the struts and lugs. Your brake shop might be trying to sell you something you don't need in the first place.
Tom in Tacoma is offline   Reply With Quote
Old 07-07-2009, 12:04 AM   #4 (permalink)
I have a touring avy. Do the kyb have two different versioin like the dealership or only one part number? Do the kyb really have "lifetime" warrenty?
Old 07-07-2009, 12:42 AM   #5 (permalink)
I just looked on kyb.com and they make only the rear struts? Where can i get the front ones?
Old 07-07-2009, 01:37 PM   #6 (permalink)
they make fronts too i cant remember wha site i got them from last year, kyb only makes one version and u will be ok with them if your a touring there wont be a major change in the ride
Old 01-11-2010, 06:46 AM   #7 (permalink)
2005 Avalon Ltd
View ManyMods's Photo Gallery
Early last year I was inquiring about suspension modifications because I wanted to firm up my OE Limited suspension on my 05 Ava. You are reporting that the KYB strust are stiffer than tourning. May I ask if you know this from first hand knowledge or how you would support your statement? TIA
ManyMods is offline   Reply With Quote
Old 01-13-2010, 07:19 PM   #8 (permalink)
Gameroom cash: $142500
View 00avxls's Photo Gallery
I have a 06 avalon and I just replaced all four of my struts with the kybs. If you have a 05 or 06 made before 1/06 then it uses the same struts as the 04-06 toyota camry v6. After 1/06 it uses the same as the 07 and up camrys. I have a limited, but I already changed out my coil springs to the touring model so I guess I have a firmer ride, but I haven't really paid attention to it.
00avxls is offline   Reply With Quote
Old 01-13-2010, 07:27 PM   #9 (permalink)
2005 Avalon Ltd
I don't have the facts on me right now about the exact production date for my '05 LTD, but I think it was April. Anyway, what I should do is replace the springs, but when I had my 2000 I replaced the struts with the Tokico HD struts and I was one happy camper. They were excellent and I recommend them highly. I guess I will have to continue driving like an old man in this car until someone steps up to the plate with an improvement, or until I dump it. Thanks for your clarification, 00avxls
Old 01-14-2010, 07:03 PM   #10 (permalink)
You pretty much have to order the springs from the dealership or go to toyotapartsbarn.com and order springs for an avalon w/sports package to get the "sportier" suspension
