So I went to auto store and bought a can of electric contact cleaner. I took the assembly out of the console and then kept disassembling until I got down to the tiny little joystick under the big button. The joystick contacts are not exposed, so I sprayed the heck out of it, worked the stick, and then sprayed it some more. Some must have gotten down in there, because it seems much better now. Still frustrating and bordering on unusable, but much better. Replacing it at like $700 is not a feasible option for me. Does anyone have a link to that hack that clears the 'I agree' button automatically? I'd be happy with either a hacked Nav CD that does it OR the one where you had to do some soldering work to the joystick assembly.
Update: The effect of this was very momentary and it went back to same symptoms very soon after. You just can't get the cleaner down into the joystick module itself or that's not the problem. I sprayed the heck out of it around the shaft and tried to 'work' it down in.
