Oil supply line - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 3rd Generation (2005-2012)
3rd Generation (2005-2012) Specific discussion of the third generation Toyota Avalon
Old 09-16-2009, 08:08 AM   #1 (permalink)
View neil5's Photo Gallery
Oil supply line
First love my 06 avalon limited no problems! Thanks to this forum and others I researched a little known TSB was in the 05 avalon then corrected. Mine was supposed to be the corrected model with an improved oil supply line! I went in for service (48K miles). The service guy said they will check it. Toyota came back and said it was "weeping" slightly and today they are replacing it (I expect at their cost). This little line if ruptures...allows you to lose you oil and many had no oil lights come on! That is why I had it looked at. I send this out since many have helped me in the past and I think its worth noting.
Happy miles
see 2005 Avalon Oil Drip or Leak TSB - EG064-05
neil5 is offline   Reply With Quote
Old 09-20-2009, 08:04 AM   #2 (permalink)
oil supply line
I got the warrantied fix at no cost. I still believe worth looking at this.
Service manager told me of one lady lost all her oil....
Old 09-20-2009, 09:06 AM   #3 (permalink)
duckprefect
View duckprefect's Photo Gallery
oil line
The new replacement line is the same as the original. It supplies the Bank 1 VVTI gear. When it ruptures this can cause cam problems, so keep your eye on the new one.
duckprefect is offline   Reply With Quote
Old 09-20-2009, 09:20 AM   #4 (permalink)
View ford_jj's Photo Gallery
oil line
Agree with you. You are right.
Thanks.
ford_jj is offline   Reply With Quote
Old 09-21-2009, 09:49 PM   #5 (permalink)
moving forward
onefiend's Avatar
View onefiend's Photo Gallery
There is a all-metal replacement as well.
V6 Camry owners are also affected ATTN: All 2GR-FE V6 OWNERS!! *UPDATE* OIL HOSE REPLACEMENT (PG 23)
2007 Camry SE V6
2003 Tundra SR5 V6
onefiend is offline   Reply With Quote
Old 10-03-2009, 03:29 PM   #6 (permalink)
View mbrem's Photo Gallery
If you don't replace the line with a solid metal one you are just buying some time because it will blow again. When?? About 40K miles from last change out. All new 09 engines have them. What does that tell you?
2008 Toyota Highlander Basic. 2WD, Salsa Red, Gray Pin Stripe, Scangage II, Gentech Mirror, Fog Lites, Vent Visors, XM Roady
2005 Toyota Avalon Limited, No Nav, XM Roady
1974 Chevy Corvette Sting Ray, 350 High Performance
mbrem is offline   Reply With Quote
