2007 Toyota Avalon driver-side rear tail-light assembly - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 3rd Generation (2005-2012)
3rd Generation (2005-2012) Specific discussion of the third generation Toyota Avalon
Old 09-25-2009, 12:05 PM   #1 (permalink)
View avalondriver07's Photo Gallery
I am having a problem removing the driver-side rear tail-light assembly for replacement. I have removed the three nuts on the protruding stems, pushed through the plastic rivet on the side, disconnected the wire and removed the two screws to the attached bracket from underneath the car. There does not seem to be any other connectors when I examine the replacement part. Yet, I can not seem to get the assembly to pop out, and I did not want to use excessive force.
Is there a special way to remove the tail light assembly?
Thanks
avalondriver07 is offline   Reply With Quote
Old 09-26-2009, 07:33 PM   #2 (permalink)
Avalon Enthusiast
Gameroom cash: $102015
View inov8's Photo Gallery
I posted the factory service manual instructions for removal here; perhaps it will help:
http://members.cox.net/n0v8or/6526 L_rear_combo_light_overhaul.pdf
(copy and paste the entire line into your browser)
This is for the 2005 model year, but 2007 should be similar.
inov8 is offline   Reply With Quote
Old 09-27-2009, 11:09 AM   #3 (permalink)
Thank you inov8 for your response and including the factory instructions. Could you please send the instructions for Hint items 1 & 2 that are referenced on page 76-6.
I appreciate your help.
Old 09-28-2009, 06:28 PM   #4 (permalink)
Avalon Enthusiast
Posted at:
http://members.cox.net/n0v8or/rear_bumper_2.pdf
There are rows of blind retainers along the seams between bumper cover and right & left quarter panels. They are not intended for re-use. Many will break as the bumper cover is pulled away. I recommend buying new ones before removing the cover.
Old 09-29-2009, 01:36 PM   #5 (permalink)
Thank you for the additional factory instructions and the tip regarding the blind retainers.
