Toyota body fasteners - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 3rd Generation (2005-2012)
3rd Generation (2005-2012) Specific discussion of the third generation Toyota Avalon
Old 11-28-2009, 04:52 PM   #1 (permalink)
View Bob Coates's Photo Gallery
In order to replace the headlight bulbs in my 2006 XLS I must remove the plastic cover at the front of the engine compartment to gain access. There are six (6) plastic rivets holding it to the frame. 1.How are these removed, 2.can they be reused, 3. is there a replacement plastic rivet available to use, and lastly does anyone have the Toyota part number for these rivets or know where I can get it. The rivets have a pin thru the center which can be moved. I pressed one down and it disappeared into the car.
**After some research I found that the part is the "cool air intake duct seal". I need the plastic clips that hold the seal to the body.**
Bob Coates is offline   Reply With Quote
Old 11-29-2009, 08:38 AM   #2 (permalink)
View sr20det's Photo Gallery
you have to pull up on the center pin, then pull the whole rivet out. they suck, they break and I only have half of mine holding my cover down.
sr20det is offline   Reply With Quote
Old 11-29-2009, 12:02 PM   #3 (permalink)
toyota fasteners
On my car the center post is just below, or even with the surface of the rivet head. I cannot pull it out from the top. My only alternative, I suppose, is to push it through, break the bottom out, and replace it. Thanks for the help.
Old 11-30-2009, 09:30 PM   #4 (permalink)
Avalon Enthusiast
Gameroom cash: $102015
View inov8's Photo Gallery
For replacements, see:
http://www.thecliplink.com/index.php...=toyota&page=7
Copy the entire URL and paste it into your browser without any line breaks.
CORRECTION: just clicking on the above link seems to work OK.
I think the part # 19552 on this page will work. You could also substitute ordinary 1/4" "Christmas Tree" plastic retainers, available at Autozone and similar stores.
inov8 is offline   Reply With Quote
Old 11-30-2009, 10:28 PM   #5 (permalink)
Part#19552 looks like a winner. Thank you kindly inov8.
