timing chain/belt - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 3rd Generation (2005-2012)
3rd Generation (2005-2012) Specific discussion of the third generation Toyota Avalon
Old 01-02-2010, 09:18 AM   #1 (permalink)
View mdlife's Photo Gallery
Question timing chain/belt
Does the third generation (2005 +) avalon engine have a timing chain or a timing belt? If a chain is there any maintenance required at mileage intervals. Is this an interference engine?
Is there a metal oil supply tube available for the third generation VVT or is the replacement still rubber and metal?
Much thanks in advance,
Dean
mdlife is offline   Reply With Quote
Old 01-02-2010, 09:55 AM   #2 (permalink)
Gameroom cash: $816901
View zythr's Photo Gallery
I don't know about your second question, but your first one, I believe it is a Timing Chain, though not 100% sure, sorry. Your owners manual should tell you, in the maintenance section. If it is a chain all you need to do is make sure that you change the oil, regularly since that is the lubrication for the chain, other than that, you need not worry about it (this is one of the reasons timing chains are better than belts, IMO) Hope this helps.
zythr is offline   Reply With Quote
Old 01-02-2010, 11:14 AM   #3 (permalink)
Avalon Enthusiast
Gameroom cash: $102015
View inov8's Photo Gallery
See:
http://members.cox.net/n0v8or/engine4.pdf
The chain guides (called "slipper" and "damper" by Toyota) are wear items and will not last forever, but I did not find any specific replacement mileage recommendation.
An all-metal VVT oil line is available from Toyota and is used on recent model year vehicles with this engine. However, Toyota dealers almost universally recommend staying with whatever style oil line your vehicle was fitted with by the factory. You can find both a picture of the all-metal line and the Toyota part number by searching recent message threads on this forum.
inov8 is offline   Reply With Quote
Old 01-02-2010, 10:23 PM   #4 (permalink)
Resident Wiseguy
Riick's Avatar
View Riick's Photo Gallery
Timing Chain
I've never seen a maintenence item for a timing chain.
They're good for a few hundred thousand miles.
No... Toyota generally does not make interference engines.
You want one of those buy a Honda (( LOL ))
YES... all the Avalon engies are the same, and the "new" all metal oli line will fit any 2005 -2009 engine.
One Tequila, Two Tequila,Three Tequila...Floor
.Gen 3 - 2005 Touring Black on Black
.2nd Toy: BMW 328ic Convertible
Riick is offline   Reply With Quote
