Original battery life? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 3rd Generation (2005-2012)
3rd Generation (2005-2012) Specific discussion of the third generation Toyota Avalon
Old 01-11-2010, 03:24 PM   #1 (permalink)
View Kellc1's Photo Gallery
2007 Limited, 41K miles. Appears I am going to be purchasing a battery soon. Seems a bit premature to me. What have others been seeing for battery life?
KC
Kellc1 is offline   Reply With Quote
Old 01-11-2010, 03:43 PM   #2 (permalink)
Do you feel lucky?
TrailDust's Avatar
Gameroom cash: $3633850
That's not unusual for batteries installed from the factory, kind of the same way OEM tires are usually crap and give you poor wear. My Highlander's batter failed after only 18 months, and when I checked the manufacturing date on the battery (which I should have done sooner) I found the battery was made two years before that. Still, three and a half years was poor longevity and it should have lasted another reliable two years.
2008 Highlander Base 4WD
2002 Avalon XL
TrailDust is offline   Reply With Quote
Old 01-11-2010, 06:40 PM   #3 (permalink)
Avalon Enthusiast
Gameroom cash: $102015
View inov8's Photo Gallery
'05 Avalon, in service July 2005. Battery failed November 2009 at 45K miles. 3-5 New England Winters is the range for all of the batteries I have owned over the past 50 years.
inov8 is offline   Reply With Quote
Old 01-11-2010, 06:41 PM   #4 (permalink)
'06 AVALON '06 4 RUNNER
CAPTMARK's Avatar
View CAPTMARK's Photo Gallery
Purchased 2 Toyota '06's in October '05 Avi & 4 runner 0 Problems with original batteries still in them and strong...
Near Zero temps here in the upper midwest
CAPTMARK is offline   Reply With Quote
Old 01-12-2010, 01:46 PM   #5 (permalink)
View mbrem's Photo Gallery
05 Avalon Limited sits outside in zero weather in Michigan with original battery going strong.
2008 Toyota Highlander Basic. 2WD, Salsa Red, Gray Pin Stripe, Scangage II, Gentech Mirror, Fog Lites, Vent Visors, XM Roady
2005 Toyota Avalon Limited, No Nav, XM Roady
1974 Chevy Corvette Sting Ray, 350 High Performance
mbrem is offline   Reply With Quote
Old 01-12-2010, 08:52 PM   #6 (permalink)
View coontai's Photo Gallery
mne cracked at the top where the hold down bolt is. changed it two weeks ago just to be safe (06).
coontai is offline   Reply With Quote
Old 01-12-2010, 09:12 PM   #7 (permalink)
'07 Avalon Limited
Tom in Tacoma's Avatar
Gameroom cash: $354645
View Tom in Tacoma's Photo Gallery
Approaching 70k miles on with the original battery.
Tom in Tacoma is offline   Reply With Quote
Old 01-13-2010, 02:30 AM   #8 (permalink)
View messerchmidt's Photo Gallery
mine was leaking acid around 90k km, swapped it for an optima red top (dry cell), and never looked back
messerchmidt is offline   Reply With Quote
Old 01-13-2010, 09:56 AM   #9 (permalink)
tonystewart's Avatar
View tonystewart's Photo Gallery
06 Limited purchased 5/19/2006
6/26/2009 60,858 miles replaced with Napa 8424F
I replaced it because I didn't want to be surprised one day. Old battery is still cranking an old diesel small farm tractor.
tonystewart is offline   Reply With Quote
Old 01-13-2010, 10:38 AM   #10 (permalink)
Do you feel lucky?
TrailDust's Avatar
They put crappy Panasonic batteries in my Highlander and Avalon, and both failed in less than two years. You'd think they'd cut you some slack and provide a decent battery, but I guess that's expecting too much from the corporate bean counters.
2002 Avalon XL
Old 01-21-2010, 06:13 AM   #11 (permalink)
View Mike Murrell's Photo Gallery
Wife has '06 Avalon - battery going on 4 yrs.
My '04 baseline Tacoma - 4 cyl battery is now over 6 yrs. old.
I thinks it's about simplicity. The more gadgetry you have, the shorter the life of the battery
Mike Murrell is offline   Reply With Quote
Old 01-21-2010, 03:42 PM   #12 (permalink)
View jag_man653's Photo Gallery
'06 Avalon XLS with NAV. Original battery doing just fine. 30700 miles.
jag_man653 is offline   Reply With Quote
Old 01-21-2010, 03:46 PM   #13 (permalink)
It Wasn't Me
boosted-fc3s's Avatar
Gameroom cash: $370780
View boosted-fc3s's Photo Gallery
07 w/ nav and a ton of aftermarket goodies, 55k, doing fine. Been 0 degrees and well below freezing for several weeks here. Just finally above freezing this past week.
2007 Avalon Limited w/ Laser Cruise 97K Miles and Counting...
2002 Dodge Ram 1500 Quad Cab 4x4
boosted-fc3s is offline   Reply With Quote
Old 01-25-2010, 03:14 PM   #14 (permalink)
Resident Wiseguy
Riick's Avatar
View Riick's Photo Gallery
Anyone who typically runs thru batteries should be buying new battery at CostCo.
7 year warranty, and effectively, if it goes out in the 1st 4-5 years, its an even swap.
I kept the battery in my old Celica going for 7 years from day car was new
by pulling it out each Fall, cleaning up everything, and then trickle charging it for a day ot two.
Batteries need some care to get longest life & good service out of them
One Tequila, Two Tequila,Three Tequila...Floor
.Gen 3 - 2005 Touring Black on Black
.2nd Toy: BMW 328ic Convertible
Riick is offline   Reply With Quote
Old 01-26-2010, 12:17 PM   #15 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $281092
View csaxon's Photo Gallery
If you don't drive it much the battery will have an early death unless you put a trickle charger on it while it sits for days or weeks. Mine lasted 7 years and I only replaced it because of sulfating around the terminals. My neighbors 06 avy sat for only 5 weeks and wouldn't crank the car. I lent him my charger to start it up and the same battery is working fine now. He uses a trickle charger now, since he doesn't drive it much.
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
