Abs/trac Bad
Your info shows Ohio - I'm N. Indiana with a used '06 xls, and the VSC/TRAC is what I dislike most about the Av. Can't spin the tires when you need to on snow & loose surfaces, and the d**n thing CUTS power to the front wheels if you're slipping while pulling out from a curb cut.
Until I got used to the looooooooooong time delay, I had several hair-raising moments trying to pull into a lane from a slippery shoulder/etc. You've got a plenty big opening, start moving, get the nose out into traffic, and the powere drops. Suddenly that traffic that was safely down the road is right on top of you, and wheels aren't moving at all. Turning VSC/TRAC is a complicated only-at-startup routine.
My humble opinion - better off without them - they increase risk.
Love it otherwise, though. Except when the oil line puked its guts on my clean garage floor...
