Originally Posted by BGEagle
For several weeks now, I have been contemplating installing XM in my wife's 2006 Avalon. But I continue to be perplexed as to where I should place the antenna. Several posters have suggested that dealerships sometimes place the antenna inside the rear brake light housing but I've closely examined the rear deck and it looks like it would be a "bear" to remove. Maybe I'm missing something. However, it seems that optimum placement of the antenna is the top of the car so that you get the best signal and the best look with the "Shark Fin". But that too looks very complex.
I don't want to order the kit until I come up with a solution to the antenna placement problem. I need some help and/or suggestions. Let me hear from you.
Note: I have been looking at other Avalons on the road and noticed that the antenna on many is located on the rear deck next to the brake light. But how did they get the wire up through the deck?
2005 Limited w/ Nav
I got a SoundLinq XM kit with the Aux option off the internet. Then got an iPlug RCA jack to use as an MP3 input, mounted it in the center storage next to the cell phone holder bracket (console behind the shifter). Had it installed at Best Buy, mounted the antenna behind the 3rd brake light on the deck lid. signal is good (could be better), but it adds aux capability, XM display through the NAV and I can plug my cell phone (which I also use as my mp3 player) into the Aux and use it as an integrated phone system (since I don't have bluetooth).
My car is black, so the antenna blends in. My wife has a Lexus ES350 with the factory XM kit and they put her antenna on the right side of the trunk (looks out of place since she has a white car). she has fewer signal drops though, but mine looks cooler . The tradeoff for the aesthetic is marginal.
