Wiring Help! - Backup Camera Install - - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 3rd Generation (2005-2012)
3rd Generation (2005-2012) Specific discussion of the third generation Toyota Avalon
Old 03-27-2010, 09:17 PM   #1 (permalink)
View sancoe's Photo Gallery
I am installing a NavTool with a locksmith minicam into my 2010 Avalon. At this point, I have the following:
1. 12V AC from NavTool Unit - connected to Gray wire (thickest) on the back of the Nav Unit
2. Ground from NavTool - connected to the screw on the Nav Unit's mount
3. 12V AC from Camera - connected to the same Gray Wire
4. Ground from Camera - connected to the screw on the Nav Unit's mount
This should have done the trick but I get no picture on my screen (GPS still works but no camera)
I was told by NavTool tech support to connect another wire labeled 12V Camera (from the NavTool Unit) to my reverse light.
Where is the "Reverse light" wire?
I have searched through the posts and found some good install instructions but these were for a 2005 Avalon. Not sure these will be the same on the 2010.
Has anyone installed a backup camera to a 2010 Avalon? If so, can you help?
sancoe is offline   Reply With Quote
Old 03-27-2010, 09:32 PM   #2 (permalink)
It Wasn't Me
boosted-fc3s's Avatar
Gameroom cash: $370780
View boosted-fc3s's Photo Gallery
Tap in near the reverse light. There should be a 12v+ red wire in the reverse light harness that goes to the reverse lights. Thats where my backup cam is tapped I believe. Though you can probably tap any one of the positive wires in that diagram if you can find them in the trunk harness.
2007 Avalon Limited w/ Laser Cruise 97K Miles and Counting...
2002 Dodge Ram 1500 Quad Cab 4x4
boosted-fc3s is offline   Reply With Quote
Old 03-27-2010, 09:41 PM   #3 (permalink)
Gameroom cash: $142500
View 00avxls's Photo Gallery
It would be the same as far as you having to connect the 12V camera wire to your reverse light wire going to your reverse light bulb. Find which of the two wires give your +12V to you reverse light bulb and connect to that wire. This is what will make the monitor switch to the backup camera when you put the car in reverse
00avxls is offline   Reply With Quote
Old 03-27-2010, 10:47 PM   #4 (permalink)
Camera Setup - Still no luck with NavTool 2010 Avalon
Guys,
Thanks for the help. I found the the red wire coming from the trunk but still no luck after connecting it to the 12v Camera wire (blue wire from the NavTool).
I'm starting to think I either have a bad camera or a bad NavTool unit.
If anyone is done a similar setup, please let me know if I am missing something.
I now have:
1. Gray from back of Nav Unit connected to 12V from NavTool
2. All ground wires on screw that connects to chassis (from Nav Unit mount)
3. Blue wire from NavTool (labeled 12V Camera) to Red wire from harness coming from the trunk (reverse light)
Any thoughts?
Old 03-27-2010, 10:50 PM   #5 (permalink)
It Wasn't Me
Do you have a meter or test light? Have an assistant start the car and put it in reverse. See if you actually have 12+ on the wire you tapped. If you have good grounds and a good reverse source, I'd suspect the unit itself.
Old 03-28-2010, 08:52 AM   #6 (permalink)
Avalon Enthusiast
Gameroom cash: $102015
View inov8's Photo Gallery
I don't think the gray wire on the Nav connector is correct. You might want to try the 2005 Nav wire colors.
Accessory +12V BLUE wire, Pin 18
Reverse +12V - BLACK wire, pin 14.
inov8 is offline   Reply With Quote
The Following User Says Thank You to inov8 For This Useful Post:
sancoe (03-28-2010)
Old 03-28-2010, 02:35 PM   #7 (permalink)
Gameroom cash: $167160
View XXagon's Photo Gallery
Did I miss something?
I don't see any mention of a connection of the video from the camera which I think should be going to M17 Connector of the Navigation unit
XXagon is offline   Reply With Quote
Old 03-28-2010, 03:28 PM   #8 (permalink)
Avalon Enthusiast
The NavTool interface should have an RCA jack for the camera video (as should the camera). An ordinary shielded video RCA male-male patch cord is used to connect the two.
Old 03-28-2010, 05:01 PM   #9 (permalink)
Made it work - Camera Install in 2010 Avalon
Inov8 was right, the gray cable was not the 12V. The NavTool tech support rep gave me bad information.
For all of those that are with the same problem, the Nav unit 18 pin connectors are the same for the 2005 and 2010 Avalons.
Got it working this morning.
Once again, thanks Inov8!
Old 04-02-2010, 03:57 PM   #10 (permalink)
View neil5's Photo Gallery
INov8
this guy is awesome
neil5 is offline   Reply With Quote
