questions on changing the brake fluid in 2006 avalon xls - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 3rd Generation (2005-2012)
3rd Generation (2005-2012) Specific discussion of the third generation Toyota Avalon
Old 04-04-2010, 01:13 AM   #1 (permalink)
View messerchmidt's Photo Gallery
Canada questions on changing the brake fluid in 2006 avalon xls
hi, 3 questions
1. whats the bleed order?
2. what fluid? valvoline super synth or ate blue?
3. should i buy one of those brake bleeder hoses that prevent air from being taken in or on of those pressurized canisters for help push the fluid through the system? or do it the old fashioned way?
thanks
messerchmidt is offline   Reply With Quote
Old 04-04-2010, 01:20 AM   #2 (permalink)
the canister thing i was taking about->
Amazon Amazon
by the hose i mean this ->http://www.toolking.com/one-man-brak...48400&LC=30527
anyone have any experience with these? junk or?
Old 04-06-2010, 09:49 PM   #3 (permalink)
rotaryboy's Avatar
View rotaryboy's Photo Gallery
I have the Motive and it works pretty well...although I have not used it on the Avalon yet. I think I have the older one that takes different caps to adapt to the vehicle, not a universal cap like your link. I would say if you are only bleeding 1 or 2 cars a year then save your money...if you do a lot more then definitely worth it.
rotaryboy is offline   Reply With Quote
Old 04-07-2010, 11:45 AM   #4 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $281592
View csaxon's Photo Gallery
http://www.bmw-m.net/TechProc/bleeder.htm
Remove then refresh the master cylinder fluid, then RR, LR, RF,LF. ATE is the best brake fluid on the planet, but I'd use the generic DOT 3 recommended by the Avalon manual and change it every other year.
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
Old 04-10-2010, 01:22 AM   #5 (permalink)
thanks guys.
I am going to use the valvoline super synth (friend brought some from the US) as its dot 3 and dot 4 (ATE is just dot 4...)
I may try and build a bleeder, but it seems easier to just buy one. thanks again
Old 04-10-2010, 01:23 AM   #6 (permalink)
also has anyone put steel brake lines on their avalon? will the stock ones from say a highlander (toyota uses Teflon, steel breaded lines on all their SUVs) work on my 06?
Old 04-12-2010, 10:50 AM   #7 (permalink)
View coontai's Photo Gallery
+1 for motive. it is a little tough to get a good sela using the universal. I have only used it on my 4runner so i do not know if there is enough space to use it on the avy
coontai is offline   Reply With Quote
