maintenance - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 3rd Generation (2005-2012)
3rd Generation (2005-2012) Specific discussion of the third generation Toyota Avalon
Old 04-06-2010, 03:42 AM   #1 (permalink)
melnric's Avatar
View melnric's Photo Gallery
maintenance
my 08 owners manual dosen't say when to change trans. fluid, timing belt ,or coolant. Help.
melnric is offline   Reply With Quote
Old 04-06-2010, 08:39 AM   #2 (permalink)
Love the Open Road!
tfelton's Avatar
Gameroom cash: $208620
View tfelton's Photo Gallery
I follow the following schedule for my '08:
Transmission Flush - 80,000
Cooing System Service - 20,000
Replace Engine Coolant - 100,000
Power Steering Flush - 20,000
Fuel System Service - 20,000
Replace engine air filter - 15,000
Replace In-Cabin Air Filter - 10,000
The engine and air filters you can do yourself.
2012 Corolla S
2006 Tundra
tfelton is offline   Reply With Quote
The Following User Says Thank You to tfelton For This Useful Post:
melnric (04-07-2010)
Old 04-10-2010, 08:58 PM   #3 (permalink)
CRESSIDA!!!
84Cressida's Avatar
Gameroom cash: $656020
View 84Cressida's Photo Gallery
There is no timing belt on the 2GR-FE. It's got a chain.
1994 Toyota Pickup Xtra cab 4x2 22R-E 44,000 mi
1998 Toyota Avalon 1MZ-FE 137,000 mi
2005 Chevrolet Silverado Crew Cab 49,000 mi
2006 BMW 330i Sedan 85,000 mi
2007 Toyota Camry Hybrid 2AZ-FXE 62,000 mi
As of May 17, 2011. DEATH TO SCION!
84Cressida is offline   Reply With Quote
Old 04-10-2010, 11:41 PM   #4 (permalink)
View TAZCOOLS's Photo Gallery
maintenence
I replace all fluids every 30,000 miles.
K&N air filter
cabin every ten
brakes fluid change when brakes done.
What is a cooling system? isn't that replacing fluid?
TAZCOOLS is offline   Reply With Quote
Old 04-11-2010, 11:40 AM   #5 (permalink)
Gameroom cash: $167160
View XXagon's Photo Gallery
Protect your warranty. In the event you have a problem with your Avalon make sure your are up to Toyota's scheduled requirements.
They provide a handy maintenance scheduling tool online at:
http://smg.toyotapartsandservice.com/
The list is tailored to your year, model and mileage.
Check it out. I think you'll find it handy.
XXagon is offline   Reply With Quote
Old 04-11-2010, 11:50 AM   #6 (permalink)
moving forward
onefiend's Avatar
View onefiend's Photo Gallery
Your Avalon has a sealed transmission without a dipstick, the manual says to get the fluid inspected at 100,000 miles
You have a timing chain, which would probably last the life of the car.
Your Avalon comes with Toyota Super Long Life Coolant (pink), good for 100,000 miles before needing a flush.
2007 Camry SE V6
2003 Tundra SR5 V6
onefiend is offline   Reply With Quote
Old 04-11-2010, 04:01 PM   #7 (permalink)
It Wasn't Me
boosted-fc3s's Avatar
Gameroom cash: $370780
View boosted-fc3s's Photo Gallery
Mine clearly has a dipstick and drain plugs. I find it extremely hard to believe that.
2007 Avalon Limited w/ Laser Cruise 97K Miles and Counting...
2002 Dodge Ram 1500 Quad Cab 4x4
boosted-fc3s is offline   Reply With Quote
Old 04-11-2010, 11:50 PM   #8 (permalink)
moving forward
onefiend's Avatar
If you have an Avalon with the 6-speed automatic tranny, then it's sealed. The 5-speed still has a dipstick.
For the 5-speeds I think the manual states a drain and fill every 15,000-30,000 miles.
2007 Camry SE V6
2003 Tundra SR5 V6
Old 04-12-2010, 10:36 PM   #9 (permalink)
Resident Wiseguy
Riick's Avatar
View Riick's Photo Gallery
My old BMW has "lifetime transmission fluid" -- NOT!
You can have the fluid changed easily using the transmission cooler lines - cost at Toy dealer should be around ?? $75 or less.
I'd do it at 50,000 miles and keep it up at that interval; cheap insurance.
One Tequila, Two Tequila,Three Tequila...Floor
.Gen 3 - 2005 Touring Black on Black
.2nd Toy: BMW 328ic Convertible
Riick is offline   Reply With Quote
Old 04-13-2010, 10:02 AM   #10 (permalink)
moving forward
onefiend's Avatar
Wrong. You obviously haven't tried it on a 6-speed auto, or don't own an Avalon with a sealed tranny.
2007 Camry SE V6
2003 Tundra SR5 V6
Old 04-13-2010, 10:14 AM   #11 (permalink)
It Wasn't Me
Lousy design. Who builds a sealed trans.
Old 04-13-2010, 11:44 AM   #12 (permalink)
Resident Wiseguy
Riick's Avatar
You're absolutely right, don't own one yet. My '97 BMW does have a "sealed" transmission, no transmission dipstick, but there are cooler lines to the radiator;
I know that since I had to disconnect them to swap out the radiator.
Are you telling me that on the 6 speed transmission:
(a) There are no transmission-fluid cooler lines to the radiator, and
(b) There are no fittings at radiator, so if radiator goes bad you can disconnect the lines and replace the radiator?
Who, in their wrong minds, would make such a setup?
Old 04-13-2010, 12:19 PM   #13 (permalink)
Gameroom cash: $818201
View zythr's Photo Gallery
Someone who does not want the tranny to be messed with unless it is by the dealer or other trained personel
zythr is offline   Reply With Quote
Old 04-13-2010, 03:47 PM   #14 (permalink)
Resident Wiseguy
Riick's Avatar
Good answer to the rhetorical question, not an answer to the actual question.
Old 04-13-2010, 04:28 PM   #15 (permalink)
moving forward
onefiend's Avatar
I don't know why you are comparing a 1997 BMW tranny to Toyota's more modern U660E 6-speed. The U660E and many of the newer Aisin units are self-contained (no radiator heat exchanger) and they can not be flushed. The tranny does have a fill-plug, drain-plug, and over-flow tube. These tranny's come with WS ATF and needs to be checked at a certain temperature, when doing a drain & fill.
2007 Camry SE V6
2003 Tundra SR5 V6
The Following User Says Thank You to onefiend For This Useful Post:
Riick (04-13-2010)
