ABS is not working - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 3rd Generation (2005-2012)
3rd Generation (2005-2012) Specific discussion of the third generation Toyota Avalon
Old 04-29-2010, 11:51 AM   #1 (permalink)
View mohaned's Photo Gallery
ABS is not working
hi
i have 2008 toyota avalon limited
the abs system is not working and the error code that apears when checking is: c1203
can anyone help me please
mohaned is offline   Reply With Quote
Old 04-29-2010, 02:09 PM   #2 (permalink)
moving forward
onefiend's Avatar
View onefiend's Photo Gallery
It's a 2008, take it to the dealer, it's under warranty.
2007 Camry SE V6
2003 Tundra SR5 V6
onefiend is offline   Reply With Quote
Old 04-29-2010, 02:57 PM   #3 (permalink)
i can't it's iraqi car there is no dealer and no waranty
Old 04-29-2010, 03:32 PM   #4 (permalink)
It Wasn't Me
boosted-fc3s's Avatar
Gameroom cash: $370780
View boosted-fc3s's Photo Gallery
C1203 says:
Engine, drive source and destination variations that are sent from the ECM do not match the ones of the skid control ECU.
Remedy is to replace the ECM according to the service manual.
Sounds like you'll need a new ECM, or need to find a dealer somewhere over in that area that can replace it for you.
2007 Avalon Limited w/ Laser Cruise 97K Miles and Counting...
2002 Dodge Ram 1500 Quad Cab 4x4
boosted-fc3s is offline   Reply With Quote
Old 04-29-2010, 04:40 PM   #5 (permalink)
i recently discovered that the rear brakes is not the same
the right one is difrent in size sounds like it's for camry
could thatbe the reason cause the traction control and the vsc is not working too
Old 04-29-2010, 04:42 PM   #6 (permalink)
It Wasn't Me
Its possible, if there is mismatched equipment on it. Is your trac/abs/vsc warming lights staying lit up? Can you take photos of the rear brakes?
Old 04-29-2010, 04:56 PM   #7 (permalink)
the ;ights are disconected they are not working even when the IG is ON
but i am sure it's not working i test the car
and i can thake pictures to the disks but give your email to send or tell me how to upload it here
Old 04-30-2010, 10:52 AM   #8 (permalink)
It Wasn't Me
Ok, so those pics you sent me, is that of the left rear and right rear, or were they one of the fronts and one of the rears? Because those are the right pads if they are a set of fronts and rears.
Old 04-30-2010, 12:59 PM   #9 (permalink)
they are rear right and left
Old 04-30-2010, 01:38 PM   #10 (permalink)
It Wasn't Me
Wow, that is definitely wrong. The smaller pads in your picture are the correct size for the rear, and the smaller caliper they go to should be correct. Your ecm is probably fine, since the incorrect brake hardware is on one side of the axle.
Old 04-30-2010, 02:07 PM   #11 (permalink)
View TAZCOOLS's Photo Gallery
YEAH ABS sensors read the brake rotation. Who messed with such a new car?
everything works better when you have the right parts.
TAZCOOLS is offline   Reply With Quote
