spark plugs - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 3rd Generation (2005-2012)
3rd Generation (2005-2012) Specific discussion of the third generation Toyota Avalon
Old 05-01-2010, 12:04 AM   #1 (permalink)
View messerchmidt's Photo Gallery
spark plugs
hi, I am going to do the spark plugs on my 05 with the water pimp,etc very shortly
I was wondering, what plugs should I use? stock or? seems that the bosh ones are causing problems. Suggestions?
messerchmidt is offline   Reply With Quote
Old 05-01-2010, 12:05 AM   #2 (permalink)
i was thinking the Bosch (4501) FGR8DQI Platinum IR Fusion Spark Plug, but people seem to be having problems with them in asian cars. Seems like denso or ngk might be the ones to get. suggestions?
Old 05-01-2010, 11:31 PM   #3 (permalink)
View toyo_tech02's Photo Gallery
I would strongly advise against using Bosch plugs on anything with an internal combustion engine. Use some Denso plugs or NGK. As far as the water pump goes... The newer generation Avalons water pumps are very good quality and very seldomn have to be changed. If you still find you desire to change it, do yourself a favor and get a Toyota pump.
toyo_tech02 is offline   Reply With Quote
Old 05-08-2010, 12:45 AM   #4 (permalink)
i got the denso ones, thanks
is there a guide for putting them in at all?
Old 03-20-2011, 10:08 AM   #5 (permalink)
View pilot737's Photo Gallery
All new Avalon's come with NGK Iridium spark plugs. These are the highest quality you can get. I have run them 100K on other vehicles. Your owners manual will show replacement plug part numbers and my 2008 shows them to be the Iridium plugs.
http://www.ngksparkplugs.com/
pilot737 is offline   Reply With Quote
Old 05-27-2011, 11:20 AM   #6 (permalink)
CISA93's Avatar
View CISA93's Photo Gallery
COmpletely agree with the NGK or Denso spark plugs and YES...by all means use a Toyota pump. I've used many after market replacement parts and have ended up paying for them with replacing them later. So stick with these critical parts with factory...there's too much after market CHinese made junk out there and the price savings isn't worth the headache. ALso...use the 100% Toyota fluid not the 50-50. you can mix it with distilled water
CISA93 is offline   Reply With Quote
