FOG Light Adjustment? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 3rd Generation (2005-2012)
3rd Generation (2005-2012) Specific discussion of the third generation Toyota Avalon
Old 05-09-2010, 10:12 PM   #1 (permalink)
View FLiPinoy's Photo Gallery
So I just installed some HID's on the low beams. I will be putting som HID's in the fog light housing as well. I noticed that my passenger side beam of light is much higher than the driver's side beam. Is there a way to manually adjust them like there is on the low beams? TIA
FLiPinoy is offline   Reply With Quote
Old 05-10-2010, 08:06 AM   #2 (permalink)
Avalon Enthusiast
Gameroom cash: $102015
View inov8's Photo Gallery
I have an '05 and the fog lamps have aiming screws that are accessible from the bottom of the housing (your screwdriver will be pointing up). Toyota advises that the final turn of the screw should be in the clockwise direction. In other words, if you are turning the screw counterclockwise toward your desired beam hieght, go slightly past that height and then turn the screw clockwise.
inov8 is offline   Reply With Quote
Old 05-10-2010, 10:03 AM   #3 (permalink)
Originally Posted by inov8 View Post
I have an '05 and the fog lamps have aiming screws that are accessible from the bottom of the housing (your screwdriver will be pointing up). Toyota advises that the final turn of the screw should be in the clockwise direction. In other words, if you are turning the screw counterclockwise toward your desired beam height, go slightly past that height and then turn the screw clockwise.
Ok, I just checked and it looks like a phillips will be used and the screw is connected to a rod which I assume is what helps adjust it up and down.
