Here's how I ended up. . . . . . . .
The "C" Pillar trim has three plastic clips and one metal one. It is extremely difficult to replace it once you get it off. However, I got lucky and found something that was not listed in the Toyota instructions. While it appeared that you could not remove it, the metal clip actually is removable. It has a plastic mechanism that holds it in place. I discovered it by accident. You can remove the metal clip along with all the plastic ones, mount them in the trim piece, then snap everything into place.
I hope this helps someone else because I struggled with the replacement until I accidentally saw that the metal clip could be removed.
Thanks again to all of you who replied to my earlier messages.
