power window problems - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 3rd Generation (2005-2012)
3rd Generation (2005-2012) Specific discussion of the third generation Toyota Avalon
Old 07-04-2010, 09:03 AM   #1 (permalink)
View weddl2's Photo Gallery
Have 06 Avalon XLS replaced battery power window control for front passenger window will not work. All others work. Anyone have remedy? Thanks
weddl2 is offline   Reply With Quote
Old 07-05-2010, 08:49 AM   #2 (permalink)
Resident Wiseguy
Riick's Avatar
View Riick's Photo Gallery
Question short disconnect
Power windows need to be reset / re-calibrated after a power-down - see manual.
BUT.. RF window not working at all?
Doubt that it has a separate fuse, but, worth checking manual.
If not fuse, then, before looking for mechanical or wiring problems,
would again disconnect battery, and be sure all power in various capacitors
in system drained by letting car sit for minimum 1/2 hour, and, crossing / shorting the (+) and (-) cables together
((No, not Battery Terminals, cables- while neither one is connected to battery))
Why? Sometimes after a short disconnect, you can have power left (in capacitors) in random places, and electronic parts act up.
((You should have seen how much trouble it was to get the Top on my convertible working right, again,
after battery was disconnected when Top was only half-way down ))
One Tequila, Two Tequila,Three Tequila...Floor
.Gen 3 - 2005 Touring Black on Black
.2nd Toy: BMW 328ic Convertible
Riick is offline   Reply With Quote
Old 07-05-2010, 10:51 AM   #3 (permalink)
Gameroom cash: $167160
View XXagon's Photo Gallery
The power window master switch and power window switch memorize the initial position of each door
window. This data will be lost if a battery terminal, fuse, or switch connector is disconnected, allowing
only a manual operation. Therefore, after reconnecting it initialize the system by performing the steps
described below.
1) Push down the power window switch and lower the window halfway.
2) Pull up the switch until the window closes and hold the switch for at least one second.
3) Make sure that the window opens and closes automatically
XXagon is offline   Reply With Quote
The Following User Says Thank You to XXagon For This Useful Post:
tfelton (07-06-2010)
Old 07-06-2010, 09:29 AM   #4 (permalink)
Love the Open Road!
tfelton's Avatar
Gameroom cash: $208620
View tfelton's Photo Gallery
I just had to use your system with the windows this morning because of a battery change.
2012 Corolla S
2006 Tundra
tfelton is offline   Reply With Quote
Old 07-06-2010, 11:51 AM   #5 (permalink)
Glad to be able to help.
