That picture is the highlander tire on the wheel. The one above it alone is the new 225 45 19. That larger tire is 245 55 19
here you go..on my 20s i have 225 35 20. the highlander is 225 45 19 so smaller wheel taller tire..everything else is the same even the off set my 20s dont rub no matter what you do...Just hopeing to clear the calipers.im gonna try em on today maybe just a front and a rear but im dieing to put the set on.
Well Guys it looks great BUT the front does catch the caliper just a tiny bit so im gonna get the smallest set of spacers.But everything else was great no rub issues when i sat my 2 buddies in the back to see if it would touch inside.nothing so it looks like a simple spacer issue.
I got a 3mm and a 1/4 inch spacer set to see which will do the job.
The 3mm did not do it.1/4inch is perfect.Stock Lugs and Studs.
